O2 Sensors ~ Noob ???
Old 01-21-2006, 04:33 AM
project93accord's Avatar
Default O2 Sensors ~ Noob ???
Where on the 93 Accord EX is the O2 sensors and is there more than 1 on this year?
Old 01-21-2006, 05:23 AM
In a Junkyard near you.
Ross 2.0's Avatar
pretty sure it only has one and that would be just below the manifold. I see in your sig all the parts you want to buy. You should look around for advice before you waste money. Search some older threads.
Old 01-21-2006, 08:21 AM
P_Adams's Avatar
Default Re: O2 Sensors ~ Noob ??? (project93accord)
MoGoGiPan is correct. OOps, (sorry MooGoCow3) still thinking about dinner last night.
The '93 Accords are an OBD1a Engine management system; and utilize just one (1) Oxygen (O2) Sensor. It will be located either in the exhaust manifold or just prior to the Catalytic Converter.
Although Bosch (and others) make universal replacement units, I'd suggest the Honda OEM item. - less problems.
Again MooGoCow3's question: why do you think you need one?
P
Old 01-22-2006, 09:57 AM
Default Re: (MooGoCow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">pretty sure it only has one and that would be just below the manifold. I see in your sig all the parts you want to buy. You should look around for advice before you waste money. Search some older threads.</TD></TR></TABLE>
In the sig what would you suggest not to get? I am new to the mod/honda world...lol
I am taking my Accord and restoring her and adding some extra bells & whistles...let me know what would be a waste of cash ...thanks
Old 01-22-2006, 05:37 PM
Ross 2.0's Avatar
Default Re: (project93accord)
"Racing Cat. Converter ~ (this spring)"
Unless your getting mad power from a turbo or stupercharger there is no need to do that. The rest of the stuff go for it. Just remember you get what you pay for especially in the exhaust parts area.
Old 01-22-2006, 07:56 PM
LewDawg's Avatar
looks like you have quite a plan for this car. It's not that you shouldn't get anything, but make sure that you do do your homework before you spend your money, otherwise you'll probably just be throwing it away.
This is your project so do what you want, but there are enough threads here that will answer what you need, if at all. Congrats on the 93 Accord, best of luck with it.
Old 01-23-2006, 10:12 PM
bresk8r87's Avatar
Default Re: O2 Sensors ~ Noob ??? (LewDawg)
the o2 sensor should be right below the header tubes, where they form 2 tubes...you probably need to take the stock header cover off to get to it...i know i did (just replaced mine last week).... other than that youre gonna need a special wrench to get it off, i believe its listed on here somewhere... its 7/8" im pretty sure.
Old 01-24-2006, 05:35 AM
amckee's Avatar
Default Re: O2 Sensors ~ Noob ??? (bresk8r87)
On the EX, the O2 is underneath the car, right before the cat. The connector is right in the line of fire for oil leaks so make sure it is clean and dry when you swap them. The Bosch will not last. Go ahead and spend the extra $30 and get a Denso or NTK.
Old 01-24-2006, 02:06 PM
Default Re: O2 Sensors ~ Noob ??? (amckee)
i had 2 replace both my valve cover and oil pan so it got leaked on...have not changed it yet will be when i replace the pipes there...no emissions control here...lol
integraguy2001
12-16-2004 06:13 PM
mika
09-29-2004 05:06 PM
alotawatts
09-20-2004 03:24 PM
TwistedSI
11
04-19-2004 07:05 AM
iam7head
10-28-2002 03:37 PM
Quick Reply: O2 Sensors ~ Noob ???
