H22A Vtec Cut off!! HELP!!!
Old 03-04-2006, 04:23 PM
duceducecord's Avatar
Default H22A Vtec Cut off!! HELP!!!
for some reason my vtec cuts off while it is still kicking it kicks about 5 somthing but then sometimes it cuts off around 6RPM and then it jus redlines at 6.5RPM i dont know wat could be the cause. I have changed the oil, sloved the leaking problem, im not sure if it is my oil pressure switch? ive also flushed my motor, Do u guys think i need a tune up?
Old 03-05-2006, 10:19 AM
momstaxi's Avatar
Default Re: H22A Vtec Cut off!! HELP!!! (duceducecord)
have you checked you oil pan for bearing flakes?
Old 03-06-2006, 10:43 AM
Default Re: H22A Vtec Cut off!! HELP!!! (momstaxi)
ive cahnged my oil it looked normail to me.. do you think i have a spun bearing or sumthing?
Old 03-06-2006, 02:50 PM
philadd's Avatar
The "Why doesn't my VTEC engage thread", from the Prelude forum:
https://honda-tech.com/zerothread?id=830163
Hopefully you can at least narrow the problem down from there.
Old 03-06-2006, 08:47 PM
Default Re: H22A Vtec Cut off!! HELP!!! (philadd)
oh kool thanks man i think i narrowed the problem i have a dented oil pan i think the punk that sold it to me hit sumthing cas its a pretty big dent
Old 03-07-2006, 09:46 AM
philadd's Avatar
Replace the pan or pound the dent out. Your oil pressure could be off b/c of the dent, which in turn would cause the symptoms that you mentioned.
Old 03-07-2006, 10:37 AM
koo thanks alot man
JDMPIG
07-03-2010 01:27 PM
da9driver
24
08-25-2005 01:00 PM
stringcheese840
06-22-2005 02:28 PM
sikek
08-10-2004 05:49 PM
mt23vtecbb2
08-22-2003 01:22 PM
Quick Reply: H22A Vtec Cut off!! HELP!!!
