HOT HOT HOT!( I really mean hot!)
Old 05-25-2002, 08:16 PM
Life is Suffering
Brandon's Avatar
Default HOT HOT HOT!( I really mean hot!)
I know this has been discussed before, but my car is running seriously hot. The car is running so hot, if I have my windows down, you can feel the heat radiating from the engine caompartment. I noticed that recently, if I don't turn the car off, the fan will not run. Is this normal? Sitting at a light for a few seconds I see the guage rise quickly and my car stalls out. I ran without using the AC for a while, but it was pointless. Please help!
Old 05-25-2002, 08:48 PM
New User
Nick H's Avatar
Default Re: HOT HOT HOT!( I really mean hot!) (vtec2k2)
my car does this too...but it's not as bad as you describe...the ac isn't ice cold and when you just run the fan on 'cold' air it isn't really cold...it's warm...i dunno what to tell you man...but mine does just about the same thing!
Old 05-26-2002, 12:10 PM
sloaccord96's Avatar
Default Re: HOT HOT HOT!( I really mean hot!) (nickh2k1)
probably a leak in the a/c somewhere?
Old 05-26-2002, 12:14 PM
I didn't ask for a dime.
Johnny Gasparini's Avatar
Have you checked to see if there is any coolant in your radiator? You also may have a thermostat that has gone bad.
Old 05-26-2002, 02:16 PM
urbantrain's Avatar
Default Re: HOT HOT HOT!( I really mean hot!) (JSM)
yeah, there's really only a few problems that would cause your car to run hot: radiator/cooling efficiency. check the level of fluid in your engine, and replace your thermostat .. (i heard jackson racing made really reallly good ones) and if that doesnt help, then you might have a leak somewhere that isnt allowing the fluid to get to your engine, if so check all your hoses (usually just the main one running from the radiator to the engine)
Old 05-26-2002, 02:37 PM
Conechaser's Avatar
Default Re: HOT HOT HOT!( I really mean hot!) (urbantrain)
If you run your heat it will help some, but i would replace the thermostat ASAP and see if that helps. O, Jackson Racing doesn't make Thermostats, they just put their names on them and sell them for a few extra dollars more than normal.
Benny Blanco
03-29-2018 04:40 PM
PeakBoostSi
07-07-2007 03:27 PM
silverb18
15
07-25-2005 03:37 PM
alb_accord
06-08-2004 07:40 PM
killerboots
12
05-20-2003 07:33 AM
Quick Reply: HOT HOT HOT!( I really mean hot!)
