Honda Civic 2000 won't start
Old 11-30-2013, 07:52 PM
PSHuertas's Avatar
Default Honda Civic 2000 won't start
My Honda Civic was starting fine everyday. Yesterday, it cranked over, but wouldn't start. Checked my fuses; all good. Checked my spark; no spark. I replaced the coil with a used one. The car started three times only. Now it doesn't start again. Can anyone give me an idea as to why it started and now it doesn't.
Old 12-01-2013, 03:48 AM
MM Gruppe B
MAD_MIKE's Avatar
Default Re: Honda Civic 2000 won't start
Welcome to the Accord Forum...
When you turn your key to ON can you hear the Fuel Pump prime? If not it may be your main relay is failing.
Old 12-01-2013, 07:54 AM
PSHuertas's Avatar
Yes, I do hear my fuel pump prime but still no spark. Any other suggestions? Also, can you tell me how many cables are suppose to bring power from the computer to the distributor when you are cranking?
Old 12-01-2013, 07:57 AM
ej6-b16's Avatar
it could be the plugs wires or the dizzy i would check all of them
Old 12-01-2013, 08:05 AM
PSHuertas's Avatar
What's the dizzy? Can you explain a little bit?
Old 12-01-2013, 09:36 AM
Zak325's Avatar
Dizzy=distributor. It is the piece that all the spark plug wires are plugged into. It basically is told by the camshaft when to send spark to which spark plug for which piston
Old 12-02-2013, 06:18 PM
PSHuertas's Avatar
I changed the distributor. Car started right up. Thank you.
Old 12-02-2013, 06:25 PM
dirty-rob's Avatar
more than likely it was the igniter inside the dizzy,real common
votex5
06-13-2013 11:51 AM
oldmc
09-02-2011 10:45 AM
DelSlowmo
61
02-12-2009 07:50 PM
Keno20
01-26-2009 10:10 PM
sikwitit
04-10-2008 05:53 PM
Quick Reply: Honda Civic 2000 won't start
