having trouble with back struts
Old 09-27-2003, 09:09 AM
delgado200376's Avatar
Default having trouble with back struts
hi my name is josue and im having a problem with the bottom bolt of the back struts.ive tride taking it out wit an air gun,air ratchet,braker bar ect . would you suggest just cutting then witha die grinder .. thank you
Old 09-28-2003, 12:42 AM
ShaolinRider's Avatar
Default Re: having trouble with back struts (delgado200376)
I just recently encountered this problem, and I just ended up cutting the old struts and getting new bushings. I'm pretty sure there other ways around, but just wanted to let you know what I did.
Old 09-28-2003, 11:42 AM
Intense3.2's Avatar
Default Re: having trouble with back struts (ShaolinRider)
I had the same problem... spray some lube on it... and pound it out with a hammer, and an object that is smaller than the hole, so that as you hammering it will slide through the hole without getting stuck as your knocking out the bolt. I forgot what the name of that little tool is called, but you get the picture.
_noname_
09-15-2005 09:19 AM
njandrewg
08-15-2004 11:58 AM
TEG98
09-16-2002 10:34 AM
Peter K
04-06-2002 01:44 PM
crewjones
08-28-2001 06:22 PM
Quick Reply: having trouble with back struts
