2003 Oxygen Sensor
Old 04-24-2005, 05:55 PM
krmdds08's Avatar
Default 2003 Oxygen Sensor
I recently ad my check engine light come on...so i pulled the code and it came back as p0141. Everything i found on the internet said that was the O2 sensor before the catalytic converter. I replaced it....cleared the code... but upon startup the light returns. Any help would be most appreciated
Old 04-24-2005, 07:44 PM
Qfactor's Avatar
Default Re: 2003 Oxygen Sensor (krmdds08)
well the P0141 is a secondary O2 heater circuit malfunction. is not the Primary(upstream).
Old 04-24-2005, 10:32 PM
deserthonda's Avatar
why was not your o2 sensor under warranty?? did you ask dealer if it was ???
Old 04-25-2005, 04:45 AM
krmdds08's Avatar
Default Re: (deserthonda)
They said 3years 36,000 miles.. i checked there web site also and it said the same thing
I was wondering if anyone had a fix for the heater circuit malfunction
Old 04-25-2005, 03:04 PM
it is part of your emissions waranty should be longer
Old 04-25-2005, 05:14 PM
metric's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">it is part of your emissions waranty should be longer</TD></TR></TABLE>
o2's are not covered under emissions waranty unlike the cat and ecu and other components which are 8/80. You will have to replace the secondary o2 sensor.
Old 04-26-2005, 04:50 AM
krmdds08's Avatar
Default Re: (metric)
So heres the deal. A certain Major Auto parts store told me that P0141 was the O2 sensor before the catalytic converter. So I knowing just enough to be dangerous belived them. So after trying everything could think of multimetering to check for shorts checking the new oxygen sensor. I decided to call my local honda dealer to see if there were any ECU software problems. When to my great enjoyment I was informed that that code refered to the sensor after the catalytic converter. This made me very happy since i already droped $140 on the first one. The so called auto parts store wanted $237 for the second one...the dealer surprisingly had it for $90....AND PROBLEM SOLVED. Thanks for all the interesting information. I know i will use this site again thanks for all the help.
Old 04-26-2005, 07:26 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krmdds08 &raquo;</TD></TR><TR><TD CLASS="quote">I recently ad my check engine light come on...so i pulled the code and it came back as p0141. Everything i found on the internet said that was the O2 sensor before the catalytic converter...</TD></TR></TABLE>A source of confusion can be the codes you get when you jumper the SCS connector & count the CEL flashing. Honda uses code 41 for the heater circuit of the 1st sensor.
OBD-2 code P0141 is defined by SAE, where the blinking-light codes were made up by Honda before OBD-2.
lsturbo*
08-15-2007 07:40 AM
slim689
04-19-2007 10:55 AM
bma1818
12
02-03-2007 10:45 AM
Mr.Speed
02-21-2006 08:15 PM
95BlkGSR
08-08-2004 05:13 PM
Quick Reply: 2003 Oxygen Sensor
