turbo help!!!
Old 02-11-2005, 01:48 PM
jdmcivic1999's Avatar
Default turbo help!!!
Ok my turbo is installed and we've had some problems over the past week and now we finally got my car running again but like usuall we hit another problem. i was letting my car warm up today and when i came back out the car was smoking. i found out its coming from where the exhaust down pipe meets the turbo outlet (where the exhaust exits from the turbo, exhaust is coming out along with some oil?? what exactly is wrong? why is oil coming out with the exhaust?? could my oil return line be plugged? would i be able to put some putty or something around it? any help would be nice.
heres my setup- 1999 sohc turbo with a turbonetics t3/t4 turbo, vortech fmu, turbonetics wastegate and gsr injectors(for now).
Old 02-11-2005, 02:12 PM
underpressure02's Avatar
Default Re: turbo help!!! (jdmcivic1999)
turbo seals bad? Are your rings shot? What is your compression and leak down numbers?
IS your return line straight?
Old 02-11-2005, 02:27 PM
s2kdre's Avatar
Default Re: turbo help!!! (underpressure02)
if there is oil coming from the middle of the turbo between the hot and cold side, then your return line is backing oil up, if its from the exhaust then seals are toast.
Old 02-11-2005, 05:39 PM
Default Re: turbo help!!! (jdmhonda)
its coming from the exhaust, and which seals are toast? and how much to replace them?
G-Auto*Hero
06-04-2009 07:26 PM
b20beast83
04-03-2009 12:35 PM
boostedcoupe1
02-20-2008 01:55 PM
90hatchblack
03-01-2007 07:57 PM
Ntrpriz
06-29-2003 08:10 PM
Quick Reply: turbo help!!!
