what injectors need a resistor box
Old 12-08-2005, 10:23 AM
Adam West's Avatar
Default what injectors need a resistor box
I want to get 1000cc injectors and they are from rc.. how do I know wether I will need a resistor box????????
Old 12-08-2005, 10:28 AM
Boostage's Avatar
Default Re: what injectors need a resistor box (Oclooc)
1000cc will need a resisitor box.
Old 12-08-2005, 02:06 PM
N20civicB18's Avatar
Default Re: what injectors need a resistor box (Boostage)
RC only makes up to 750cc's that dont need a resistor box
Old 12-08-2005, 03:38 PM
SilCiv2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oclooc &raquo;</TD></TR><TR><TD CLASS="quote">I want to get 1000cc injectors and they are from rc.. how do I know wether I will need a resistor box????????</TD></TR></TABLE>
use a meter to check for resistance on the injector coil. low impendence- 2-4 Ohms (u need a resistor box)
high impendence 12-15 Ohms (no resistor box) this way you can know for sure.
Old 12-08-2005, 03:53 PM
520_Motorsports's Avatar
Default Re: what injectors need a resistor box (SilCiv2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">RC only makes up to 750cc's that dont need a resistor box</TD></TR></TABLE>
Saturated injectors don't need one and peak/hold injectors do!!!! usually when you buy the injectors they specify weather or not they are saturated or peak/hold.
Old 12-09-2005, 04:08 AM
Adam West's Avatar
Default Re: what injectors need a resistor box (SlowAzEg)
the rc are peak hold... whats the difference between saturated and peak hold???????????
Old 12-09-2005, 04:50 AM
PM-Performance's Avatar
Low impedance need resistor boxes. Hi's dont
Old 12-09-2005, 04:59 AM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oclooc &raquo;</TD></TR><TR><TD CLASS="quote">the rc are peak hold... whats the difference between saturated and peak hold???????????</TD></TR></TABLE>
Saturated injectors have a "built in" resistance of around 12-16 OHM. Peak and hold injectors only have a resistance of around 2-4 OHM. So with P&H injectors you need resistors or a resistor box to raise the resistance.
Also here's something I posted a long time ago about P&H vs Saturated
https://honda-tech.com/zerothread?id=1126948
Old 12-09-2005, 05:36 AM
Adam West's Avatar
Default Re: what injectors need a resistor box (BlueShadow)
thanks alot.. I am going turbo and wanna buy injectors now cause someone is selling some for 200 and they are 780cc'c... That might be enough but it has no resistor box.. I think it might be enough for up to 450 hp.... is this a good deal of should I get the 1000cc's from rc on ebay for 316??????????????
Old 12-09-2005, 05:46 AM
BlueShadow's Avatar
How much boost do you think you'll be running to get 450 HP? According to my calculations 780's would be good for about 420-450 HP at 85% duty cycle, but this is NA. You may be able to get more power out of the injectors, depending on how much boost you run.
Old 12-09-2005, 05:59 AM
Adam West's Avatar
ok here are my intentions..... I want to go b20.. so I am buyin the motor by the end of the month cause I am shopping around for deals..... now when I get it I wanna have it runinn and get it passed inspection on my p75 ecu.... once thats accomplished I want to go boost... my first question is 1) should I buy a block gaurd or get it sleeved???????? once I bolt the turbo on I want to up the limit to about 8700... I want to put a skunk2 manifold on it (please give your opinions on the manifold) and I want to put on the injectors??? those are the first mods I want to do..... the turbo will be a t3/t04 turbo with more than likely a love fad manifold for like 550 or something.... (please give your opinions on the type of manifold you think would be better)
Old 12-09-2005, 06:30 AM
BlueShadow's Avatar
Aside from a custom manifold the JG Edelbrock Victor-X seems to be the best. People say there are lots of gains in the upper RPM ranges, but you'll loose a little lower RPM range performance.
BTW check out this thread that I just created. Your question about how much HP the 780cc's kinda got me thinking about some things.
https://honda-tech.com/zerothread?id=1458404
Old 12-09-2005, 07:03 AM
anything bigger then 550's will be good for 450hp.
Old 12-09-2005, 07:16 AM
Adam West's Avatar
Default Re: what injectors need a resistor box (itr206)
I figured better safe than sorry.. so when I put these injectors on a stock car it wont be supplying all 1000cc's until I turn up the fuel right????????
skeetahendo
03-15-2008 03:44 AM
jdmray
10-23-2007 06:18 PM
spooned out
08-14-2005 09:18 PM
MysteryWagon
06-17-2005 04:16 AM
careawholelot
08-03-2004 02:26 AM
Quick Reply: what injectors need a resistor box
