Turbo b20 sputtering issues need help
Old 08-08-2014, 08:32 AM
Midnight_runs's Avatar
Default Turbo b20 sputtering issues need help
Ok so i just went turbo a few days ago and im having a issue with the car sputtering after 1/4 throttle at any rpm . If i only hold it 1/4 way it will go to redline no problem and build boost. As soon as i go any more the car just sputters and pops wont move but still builds boost.
But the first night i drove the car i had my foot to the floor and it was fine i didnt have this issue . Any advice would be appreciated.
Spark plugs are gaped to .30
Stock fuel system
Chipped obd1 ecu with a basic tune
I tryed advancing the dizzy all the way just to see if it would make a difference and it no longer sputtered untill i put my foot completely to the floor , but i risk detonation if i drive it like tht so im a little confused
Old 08-08-2014, 08:51 AM
DC4KiD's Avatar
Default Re: Turbo b20 sputtering issues need help
"Chipped obd1 ecu with a basic tune"
Is that an actual tune, or a "basic tune" as in... a base map that someone just burned/loaded on to a chip for you?
Old 08-08-2014, 09:09 AM
A base map tht someone burned for me
Old 08-08-2014, 09:19 AM
Eight09's Avatar
So why dont you get it tuned?
Old 08-08-2014, 09:20 AM
boosted94gsr's Avatar
You need to get it tuned asap. If you keep driving it like that you will damage your engine. Base maps are only to get you to the tuner. You should stay out of boost until its tuned properly.
Old 08-08-2014, 10:17 AM
Anything i can do for a temporary fix ?
Old 08-08-2014, 10:32 AM
F22Master's Avatar
Unhook the charge piping before you melt a hole in your pistons or crack a sleeve...
Let me.guess, stock.injectors too?
Old 08-08-2014, 10:51 AM
Eight09's Avatar
yea
Get it tuned
Old 08-08-2014, 06:10 PM
blackeg's Avatar
sounds like it, it says stock fuel system.
take the wastegate off or the spring out depending on internal or external, or take off a pipe like you said. whatever it is dont let the thing go into boost. get it tuned asap. its could be running a **** enough tune to damage the motor without boost
Old 08-08-2014, 06:49 PM
Runnerdown's Avatar
Classic
Hondadaturbo
Engine Management and Tuning
04-16-2010 11:26 AM
blasterman87
09-26-2009 04:29 PM
ser13
05-29-2009 05:31 PM
Nsane1
04-19-2005 10:08 PM
PressurizedSi
12-30-2002 06:15 AM
Quick Reply: Turbo b20 sputtering issues need help
