No compression.
Old 08-31-2015, 11:11 AM
GT500FTW's Avatar
Default No compression.
Hi guys.
I've got very little compression on 3 cylinders after 1/4 mile pull.
It's a b16a2 running 8psi with 270whp.
I was racing on Sunday, and as I let off the throttle at the end of the 1/4, plumes of white smoke started coming from the exhaust.
I presumed it was head gasket, so I took it apart today to check. The gasket looked fine. I checked the Block and the head to look for anything obvious, but it all seemed fine.
I turned the head upside down and poured some turps in the combustion chamber to see if there was an obvious leak. - nothing.
I poured some into the cylinders to see if the Piston rings were fucked. - nothing.
I put on a new HG and torqued to spec and the same 3 cylinders gave me the same readings.
What could cause white smoke and low compression on 3 cylinders?
Old 08-31-2015, 11:15 AM
civic-steve-94's Avatar
Default Re: No compression.
Did you take a straight edge to the head? Are you using head studs or factory bolts? If bolts did you measure them to see if they stretched?
Old 08-31-2015, 11:19 AM
GT500FTW's Avatar
I checked the timing before I took it apart and it was fine. (And poor timing wouldn't cause steam) AFAIK.
Old 08-31-2015, 11:21 AM
GT500FTW's Avatar
I'm using arp head studs.
I didn't check the head with a straight edge. I feel like such a noob!!!
Old 08-31-2015, 11:28 AM
turbohatch96y7's Avatar
Cracked ring lands bro <br /><br />Theyre prolly still in place <br /><br />Do a leak down test
Old 08-31-2015, 11:37 AM
GT500FTW's Avatar
Is it likely that 3 Pistons cracked their ring-lands on one run?
I'm leaning towards a warped head at the moment. Just because:
Cylinder 1 - 4bar
Cylinder 2 - 6bar
Cylinder 3 - 8bar
Cylinder 4 - 15bar
If the ring-lands went, it wouldn't really cause steam. Plus I checked the bores and they were in good condition.
Of the ring lands went, I'd expect some scoring.
Old 08-31-2015, 11:56 AM
Dark_Teg's Avatar
When my ringlands went nothing was damaged, everything stayed in place till I removed the pistons then I had chunks of ringland in my hand. It 100% sounds like your ringlands gave it up.
Old 08-31-2015, 11:57 AM
GT500FTW's Avatar
Would that cause white smoke?
Old 08-31-2015, 12:01 PM
Dark_Teg's Avatar
Put compressed air into the cylinder with the valves closed. You will be able to easily tell whats messed up by where you hear the air escaping from. I pressured up #3 and had air roaring out of my catch can. No-brainer at that point.
Old 08-31-2015, 12:30 PM
That psi is stupid low <br /><br />Leak down test for sure doesnt matter what anyone says <br /><br />Is smoke coming out of the catch can? Does the motor even run? Any shavings in the oil?
I never narc'd on nobody!
NotARaCist's Avatar
<p>Oh hey, a DIY I've covered in my build thread!</p><p>https://honda-tech.com/honda-civic-d.../#post50363409</p><p>Do that. &nbsp;It'll tell you exactly where your air is going.</p>
Old 08-31-2015, 12:51 PM
GT500FTW's Avatar
Yeah it's only a small turbo.
Yes. Smoke is coming from the catch can.
It does run if you keep the revs up but it doesn't want to idle.
Oil looks fine.
Old 08-31-2015, 01:02 PM
I meant ur compression test results if thats what those numbers were
dfJDM
23
02-16-2011 11:31 AM
wicked_b16eg
12-29-2007 06:39 PM
quick87crxsi
11-26-2006 05:42 PM
BoostedSi
04-20-2002 04:21 PM
Turbohatch
07-03-2001 11:47 AM
Quick Reply: No compression.
