Which injector seals (ID1000 + d16y8 manifold)
First off, I already searched and found some similar information in this thread:
https://honda-tech.com/forums/forced-induction-16/id-siemens-thin-long-injector-b-series-3026226/
I put some ID1000s into my Civic which is running a d16y8 intake manifold. The problem I am having is that although the injectors are spaced correctly using the aluminum top hats I recieved from Evans Tuning, the injectors are too thin to properly seal in the intake manifold.
Is there an injector seal that I can get which will properly seal the space between the injector and the intake manifold? I did not have this problem with my FIC 850cc/min injectors since they were "fatter" and did not have any issue with leaking from around the intake manifold injector seals.
Re: Which injector seals (ID1000 + d16y8 manifold)
you need to order these washers they will keep the injectors from going to far in the intake manifold http://www.xenocron.com/washer-set-f...ors-p-295.html
Thanks for the reply.
the washers go around the bottom of the injectors and no you do not need a different seal just use the stock one
TurboB18C1
10-09-2002 10:56 AM
