Downpipe bolts -- Why are they becoming loose!?!?
Old 09-25-2003, 12:06 PM
TRE_'s Avatar
Default Downpipe bolts -- Why are they becoming loose!?!?
So heres the deal --> I constantly check my exhaust bolts, vacuum lines, spark plugs, etc and about a month ago i started to hear an exhaust leak, so i checked the bolts that hold the downpipe to the turbo and it turns out that they were loose. so i tightend all of them up so they were nice and snug. stayed that way for about a week, then they were all somewhat loose again. So every 5 or so days I find my self tightening the bolts that hold the downpipe on the turbo. Tightened them all 3 days ago, and I go to check them today and to my suprise one is tottaly gone, one is halfway out, and the others are all fairly loose. What could be causing this? I have no idea how to remedy this problem... maybe the bolts are too short or something? Has anyone else had this problem, and do you have any reccomendations??
Thanks guys, sorry if the post is confusing...
Old 09-25-2003, 12:10 PM
gritsak's Avatar
Default Re: Downpipe bolts -- Why are they becoming loose!?!? (glowing_turbo)
vibration is prolly causing them to work themselves out....try putting a tab of locktight on them (im not sure if theres a temp limit on it? ide check that out)
Old 09-25-2003, 12:11 PM
Mr. Softee's Avatar
id make sure you are using the right size bolts... sometimes the metric/standard can be close in size. also make sure you are using a decent grade bolt, lower grade ones aren't always cut as close to spec. finally id make sure they are really as tight as you think... i know when i am in ther ei am using like a 5" long wrench.. tightening real tight with a 5" long wrench when you are in there at a shitty isnt always as tight as you think.
sam
Old 09-25-2003, 12:12 PM
boostaholic's Avatar
Combination of heat and vibration will cause them to start backing out. Try using some high temp locktight or using some studs with some lockwashers instead of bolts.
Old 09-25-2003, 12:48 PM
TRE_'s Avatar
Default Re: Downpipe bolts -- Why are they becoming loose!?!? (boostaholic)
thanks for all the suggestions.... it seems like the gasket inbetween the downpipe and turbo is to thick and its not letting all of the bolt thread in. a friend of mine reccomended that i take that gasket out and replace it with a thin layer of high temp silicon.... you think that would work?
Old 09-25-2003, 12:51 PM
Smarter than you
DIRep972's Avatar
you don't need a gasket right there. Do u have a flex pipe? are all of ur motor mounts good? Try putting in studs w/ nuts and have a muffler shop make a bracket from the downpipe to the motor for support.
quikB18B's Avatar
* Pull out the stupid bolts
* Replace with studs/nuts
* Use lockwashers/Locktite
* Use atleast grade 8 bolts
* Tighten them and you should have no probs.
Im using studs/nuts and i havent had any problems .
Tony1 also told me that using the nuts from honda( exhuast manifold) will also help because they have that flange on the end
Modified by quikB18B at 2:02 PM 9/25/2003
Old 09-25-2003, 12:53 PM
JDMCRX's Avatar
Default Re: Downpipe bolts -- Why are they becoming loose!?!? (quikB18B)
2 opions
use Honda exh studs and nuts
or use hardened lock washers and nuts but make sure they are hardened steel
Old 09-25-2003, 12:54 PM
JDMCRX's Avatar
Default Re: Downpipe bolts -- Why are they becoming loose!?!? (JDMCRX)
Oh and also make sure u have ur rear downpipe brace mounted that makes a big difference alot of people are too lazy to put them on
Old 09-25-2003, 12:55 PM
Teg4e's Avatar
this used to happen to me all the time. one, two, sometimes three of the five bolts would come off. Solution: put on lock washers. i haven't had one fall off since.
Old 09-25-2003, 01:18 PM
TRE_'s Avatar
awesome, thanks for all of your help guys, its REALLY helpful. yes i have a flex pipe.... which i plan on getting a bracket for extra support. how hard is it to replace the bolts with studs?
Old 09-25-2003, 01:29 PM
quikB18B's Avatar
Default Re: (glowing_turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by glowing_turbo &raquo;</TD></TR><TR><TD CLASS="quote"> how hard is it to replace the bolts with studs?</TD></TR></TABLE>
Just screw in the stud use loctite and make sure its tight and then mount up downpipe once studs are secure, and then slide on lockwashers, screw on nut and tighten away.
Heres a thread on everything you wanted to know about bolts, thread sizing, ect....
It doesnt have exact sizes on lenght of stud you need, but just get something that will give you enough room to tighten the nuts. For example thread shows 20mm needed for lenght of bolt, i used a 30mm stud
https://honda-tech.com/zerothread?id=373905
Old 09-25-2003, 01:52 PM
boosted_dc2's Avatar
Default Re: (quikB18B)
what i did was take off my mani and everything on a bench, use lock washers and hig temp loctite, tighten the fock out of them on the bench, then reinstall everything. you cant really get them that tght when its on the car cause you have no leverage...
Old 09-25-2003, 02:30 PM
Trac226's Avatar
Default Re: (boosted_dc2)
I used to have that problem as well, having a flex pipe helped.
Old 09-26-2003, 09:54 AM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=373905</TD></TR></TABLE>
awesome; thanks for the info and link.
Old 09-26-2003, 09:56 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikB18B &raquo;</TD></TR><TR><TD CLASS="quote">* Pull out the stupid bolts
I agree. But make sure you use the JDM loctite
Old 09-26-2003, 10:19 AM
xenocron's Avatar
Default Re: Downpipe bolts -- Why are they becoming loose!?!? (GudeH23a)
Where is the best place to pick up these bolts?
NAPA, Autozone, Sears, Home Depot...?
I figure their stuff is pretty cheap and wont last. Are there any high quality bolt/stud manufacturers of mention?
Old 09-26-2003, 10:32 AM
quikB18B's Avatar
Default Re: Downpipe bolts -- Why are they becoming loose!?!? (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">Where is the best place to pick up these bolts?
I figure their stuff is pretty cheap and wont last. Are there any high quality bolt/stud manufacturers of mention?</TD></TR></TABLE>
I got mine from Ace hardware, my suggestion is pull out the phone book and start calling. Not all places carry the sizes we need, let alone in a stud. So dont waste yor gas driving around town searching for them. Ace hardware's are independently owned so the one by my house only had the correct thread sizes in bolts, not studs. I had to go to a different ace to pick them up.
DrivinVtec
06-12-2008 08:56 AM
swlabhot
04-29-2003 08:19 AM
hybrid901
06-07-2002 03:09 PM
austrian type-R
04-19-2002 07:56 AM
Quick Reply: Downpipe bolts -- Why are they becoming loose!?!?
