B18C5 Rattling?!
B18C5 Rattling?!
I have a recently fully built type r block with a fully built gsr head. it was running well when i first turned it on but later i started to hear a rattle so i adjusted the valves and i still hear the rattle just not as bad any more can some one please help me with this problem!
can I haz?
Re: B18C5 Rattling?!
what is your oil pressure? it could be your bearings, dont drive it as it will only damage the engine more and be harder to fix. Drain the oil to see if there is any metal shavings in it.
set the valve lash again.
Who is Mr Robot?
forged bottom end?
forged pistons will slap when cold
and remember... valve lash needs to be set when the motor is absolutely cold
I drained the oil and saw no metal shavings and i changed the oil to 50sae and i still hear the rattling.
