KNOCKING.....cold...35psi oil????
Munkyw3rkz.webs.com
1 Post
ok i have noticed that my B18C1 has been giving me the thoughts that its knocking....
my question is will the motor knock when its cold right at start up?
i figured it was cold but after it was sorta warm it was still knocking oil pressure was at 35 but i also noticed that after warming up more it goes away and oil press is at 20....motor still pulls....what gives
Munkyw3rkz.webs.com
1 Post
Re: KNOCKING.....cold...35psi oil???? (Revolveu2)
normal???
i hope so.....ill be taking off the head in a fe weeks so imma check out the internal while im at it......
any other possibilities????
Re: KNOCKING.....cold...35psi oil???? (SnoFlake EG)
Do you have forged pistons? If you do then it probabally is piston slap. The oil pressure is supposed to go down went your engine warms up because the heat causes the oil to thin. The thinner your oil is the less your pressure will be. Hope that helps.
Re: KNOCKING.....cold...35psi oil???? (AREA 51)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AREA 51 »</TD></TR><TR><TD CLASS="quote">I think that motor is gonna blow bro !
shut up foo don't scare Santos lol...
Munkyw3rkz.webs.com
1 Post
yea bra dont say that .....im sure it will be aiight once i change the head out for the built one while im at it im changing the belt just to be safe
Modified by SnoFlake EG at 6:02 PM 1/18/2004
when its slapping next time, try doing a power balance test. pull 1 plug at a time, if the noise dissapears once you pull a plug you might have a bad rod bearing. if your unsure drop the oil pan and check for shavings. hopfully not good luck!
Munkyw3rkz.webs.com
1 Post
Re: KNOCKING.....cold...35psi oil???? (9sech22civic)
just went to start the car since its been sitting and its cold to see if it did it and right now it didnt do it......i just realised that it does it when im goign to work after a cold night which is in like the 30's could that be something?
som etype of loose clearance for sure. warm metal expands = tighter clearances = quieter.
cold = loose and noisy. = somethings worn out or out of spec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnoFlake EG »</TD></TR><TR><TD CLASS="quote">just went to start the car since its been sitting and its cold to see if it did it and right now it didnt do it......i just realised that it does it when im goign to work after a cold night which is in like the 30's could that be something?</TD></TR></TABLE>
Does it really get that cold in that part of Cali?
under your avatar it says you live in Inglewood...
Munkyw3rkz.webs.com
1 Post
Re: KNOCKING.....cold...35psi oil???? (superbowlizghey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superbowlizghey »</TD></TR><TR><TD CLASS="quote">
under your avatar it says you live in Inglewood...</TD></TR></TABLE>
lol yea up here near Fresno it does...i hate it ...im a troplical ***** fugga....
mdb4879
08-09-2016 05:14 PM
freeplay
10-14-2002 06:06 PM
infamousALLMTR
04-02-2002 03:28 PM
