Turbo problem helpp
Old Aug 7, 2011 | 06:21 PM
Hiboost 2.0's Avatar
Icon2 Turbo problem helpp
delete
Old Aug 7, 2011 | 06:40 PM
LocoJoe's Avatar
Default Re: Turbo problem helpp
I dont know but white smoke means water............ could be head gasket.
Old Aug 7, 2011 | 06:42 PM
i kno but head gasket would smoke while the cars just running .. i think cuz the car got 2 types oil lol
Old Aug 7, 2011 | 06:43 PM
LocoJoe's Avatar
Maybe the head is lifting at full boost only.........
Old Aug 7, 2011 | 06:59 PM
very true
Old Aug 8, 2011 | 07:05 AM
bummppps for some help
Old Aug 8, 2011 | 07:15 AM
ShanghaiOC's Avatar
Are you using stock head studs? It sounds like head lift under full boost...I had this issue before on the old design of Cometic head gaskets. Check your head gasket & buy some head studs.
Old Aug 8, 2011 | 08:44 PM
dopehouse's Avatar
were you running conventional oil before you switched to full syn? on my bmw i had no syn so i put conventional in and it smoked at high rpms. i changed the oil and put the regular full syn and it stopped after like 10 mins. also how many miles on the motor? if you have high miles or brand new rings the full syn will somtimes slip right past the rings and could cause breakin broblems on new rings. just my 2cents and experiance
Old Aug 9, 2011 | 04:21 AM
mangina's Avatar
when oil burns it is blue color.
head is probably lifting.
Old Aug 9, 2011 | 04:53 AM
Turbo-LS's Avatar
The difference in exhaust color especially when your driving and cant se from behind is hard to tell. On 8 psi of boost i dont think your making enough power to lift the head BUT anythign is possible. You could be lifting under boost but that usually is followed by a spike in engine temps from the exhaust gases getting into the coolant passage
What size oil feed and drain on the turbo? any restrictor?
next time you make a pull check your temp and see if its starts to run hot, check for oil in coolant or coolant in oil as well. Unless the timing is super aggressive on that power level i dont think it would be a cracked sleeve
Old Aug 9, 2011 | 09:48 AM
I do have a restrictor not sure on the size i thought that was the problem to begin with .. so i went an ordered this http://cgi.ebay.com/ebaymotors/OBX-T...Q5fAccessories witch was a hair to big an the oil feed line wouldnt fit to the head of the restrictor .i fixed the oil return line i noticed it wasnt running on a down slope back to the oil pan so i pulled it off to fix it an when i did that alot of extra oil just poored outa the line so im thinkin it wasnt gettin the proper drain back into the oil pan ...
Old Aug 10, 2011 | 04:53 AM
Turbo-LS's Avatar
That could definatly be your issue, if oil isnt draining properly it backs up into the turbo and leaks real quick. try that and see what goes
Old Aug 10, 2011 | 07:40 AM
ShanghaiOC's Avatar
That tad bit of info does help us. Have you tried running the car since you fixed the oil return line? Issue resolved?
Old Aug 10, 2011 | 08:08 AM
nah not yet i will today tho
Old Aug 10, 2011 | 07:50 PM
So i started up my car today didnt drive it at all .. after adding the new oil return line just wanted to see if there was any leaks an there wasnt so i took some pics of the of my gauges an just wanted to make sure thay was rite
Old Aug 10, 2011 | 08:00 PM
pcguy760's Avatar
At what idle was your gauge readings taken and was the car fully warmed up?
Old Aug 10, 2011 | 08:10 PM
1300 an yea fully warmed up an this was at idle when pic was taking
Old Aug 10, 2011 | 09:47 PM
civickiller's Avatar
alittle rich for idle on a stock motor
Old Aug 10, 2011 | 10:14 PM
How could i fix this ? is it really bad ?
Old Aug 10, 2011 | 10:23 PM
My idle is at 1300 should i turn it down a bit ?
Old Aug 11, 2011 | 08:35 AM
Turbo-LS's Avatar
should idle 750-900 rpm and a/f ratio should be 14.7-15.5
Old Aug 11, 2011 | 08:49 AM
so turning down my idle should help ? an im not sure but i may have bad gas its ben in there for a long time
Old Aug 11, 2011 | 09:36 AM
dopehouse's Avatar
is your turbo water cooled? maybe its leaking under boost. also did you ever change your oil back to original?
Old Aug 11, 2011 | 11:10 AM
no just air to air cooled .. an no havent changed it yet should i run fully syn 10w-30 ??
Old Aug 11, 2011 | 11:34 AM
TheShodan's Avatar
Moderator
no just Oil cooled .. an no havent changed it yet should i run fully syn 10w-30 ??
Fixed
