sump really needed?
Old 12-04-2010, 12:19 PM
Ant@backyardracing's Avatar
Default sump really needed?
hi all, im re-doing my car for the 2011 season, and upgrading the fuel system as req`d, as i currently run just the in-tank walbro, which has served me well tbh.
anyway, i want to run twin bosch 044 pumps next year (b18 72mm setup now) now i see most run a sump, but i dont want to do it purely for bandwagons sake, and seeing as the stock tank design has an anti-slosh section where i would take my feed for the bosch pumps, i just cant see why a sump is needed. has anyone done a twin 044 setup, just pulling there own fuel from the stock location, just with an increased bore pickup/feed? are the 044`s ok as suction pumps? i realise i wont be able to run tiny amounts of fuel in the tank, but i dont anyway, as were weight limited in my drag class, and im underweight as it is.
2nd point, where do you guys get your -10 an fuel rails? golden eagle is the biggest i can find but thats only -8?
cheers guys
Old 12-04-2010, 12:44 PM
narfdanarf's Avatar
Default Re: sump really needed?
why do you need a -10an rail?
Old 12-04-2010, 12:57 PM
well im going to run -10an lines, as per the norm, so seems logical to fit a rail of matching bore. i think full blown do a -10an rail?
Old 12-04-2010, 01:10 PM
lugnuts's Avatar
I strongly prefer running a surge tank.
This allows you to keep your unmolested oem style pump, which can fill the surge
tank easily and reliably.
2x Bosch 044 pumps into -10 is a great set-up.
And I like running large diameter fuel rails, the increased volume reduces the pulsations
in the rail caused by the injectors opening and closing.
Old 12-04-2010, 01:14 PM
yes that was another plus of the larger volume rail, as i will be binning the stock anti-pulse canister. i did think about a surge tank, but im a bit stuck as to mounting it, as i cant have any fuel in the cabin, and i cant see where one would fit anywere else. i notice a lot of you guys dont run surge tanks anyway, or thats the impression i got from the "post your fuel system and questions" thread.
Old 12-04-2010, 06:50 PM
cibao2ner's Avatar
i think full-race makes a -10an fuel rail...check their site..
Old 12-05-2010, 10:33 AM
so anymore input guys
any of you with this setup? (no sump feeding 2x bosch pumps?)
Old 12-05-2010, 11:11 AM
SPOOLINmatt's Avatar
i didn't realize sumping was a bandwagon LOL. Just sump it and be safe and sound.
Old 12-05-2010, 11:27 AM
tony1's Avatar
I wouldn't call a sump 'safe and sound'. It's a horrible way to get fuel out of a short and wide tank.
Old 12-05-2010, 11:37 AM
Spoolin18's Avatar
Why not purchase the FCS fuel cell with the sending unit? It's a great piece, holds 5.1 gallons and mounts in the stock tank location.
Old 12-05-2010, 12:50 PM
why if theres nothing wrong with the stock tank?
Old 12-05-2010, 12:57 PM
i know the shape of the stock tank is not perfect, which is why i thought a tall narrow surge tank would be the way to go, but since i cant really fit one anywhere on the car, thats out.
so im just looking for peoples actual experiance from running powerfull pumps sucking there own supply from stock location pickups, did you suffer air bubbles etc?
Old 12-05-2010, 01:02 PM
Spoolin18's Avatar
The stock tank tends to rust out, etc. I'm sure the inside of your tank isn't in the best condition...no ones really is. If you use the FCS cell or any other aluminum cell it is a closed system. This is what I just did, and I run absolutely no filters. In the end, it is the better way to go.
Old 12-05-2010, 01:13 PM
locash's Avatar
Absolutely no filters? I'm not sure thats something I would ever do. At the very least, one before the fuel rail.
Old 12-05-2010, 01:14 PM
im putting the FCS fuel cell on this week thank goodness! Tony i agree the sump on a stock tank isn't the best thing out there for sure, ESPECIALLY for street driving lol. I hate hearing my pump starve everytime i hit the brakes even with 5 gallons in the tank.
Old 12-05-2010, 03:48 PM
jdm inc's Avatar
full blown has a -10 fuel rail
http://www.fullblownmotorsports.net/...products_id/68
Old 12-05-2010, 05:19 PM
gogetta's Avatar
Serious question.. has anyone ever tried shrinking the stock tank down to say 5-6 gallons.
Old 12-05-2010, 06:40 PM
cotorresgee's Avatar
why not run the dual walbros? people have made plenty of good power with them. Supra guys run triple walbros and make good power as well.
Old 12-05-2010, 10:13 PM
MrParks's Avatar
running into any moisture/ oxygenated fuels will rust the oem tank after being cut. you will definitely need to coat the inside of a oem tank after being modified in any way.
ive seen a coated tank after and they will never be 100% coated inside.
Old 12-07-2010, 05:34 AM
hello1320's Avatar
X1000000000.
Old 12-07-2010, 08:33 AM
so i take it not many people run large/twin pumps from stock pickup point then with no sump lol
Old 12-07-2010, 08:34 AM
paulzy's Avatar
full blown and edelbrock both make a 10an fuel rail
Tippyman
09-08-2013 01:41 PM
jsbayer
09-01-2009 07:17 PM
92hondalude
04-15-2009 02:57 PM
Soon_2b_evil
04-04-2005 03:56 PM
Quick Reply: sump really needed?
