sump really needed?
Old Dec 4, 2010 | 12:19 PM
Ant@backyardracing's Avatar
Default sump really needed?
hi all, im re-doing my car for the 2011 season, and upgrading the fuel system as req`d, as i currently run just the in-tank walbro, which has served me well tbh.
anyway, i want to run twin bosch 044 pumps next year (b18 72mm setup now) now i see most run a sump, but i dont want to do it purely for bandwagons sake, and seeing as the stock tank design has an anti-slosh section where i would take my feed for the bosch pumps, i just cant see why a sump is needed. has anyone done a twin 044 setup, just pulling there own fuel from the stock location, just with an increased bore pickup/feed? are the 044`s ok as suction pumps? i realise i wont be able to run tiny amounts of fuel in the tank, but i dont anyway, as were weight limited in my drag class, and im underweight as it is.
2nd point, where do you guys get your -10 an fuel rails? golden eagle is the biggest i can find but thats only -8?
cheers guys
Old Dec 4, 2010 | 12:44 PM
narfdanarf's Avatar
Default Re: sump really needed?
why do you need a -10an rail?
Old Dec 4, 2010 | 12:57 PM
well im going to run -10an lines, as per the norm, so seems logical to fit a rail of matching bore. i think full blown do a -10an rail?
Old Dec 4, 2010 | 01:10 PM
lugnuts's Avatar
I strongly prefer running a surge tank.
This allows you to keep your unmolested oem style pump, which can fill the surge
tank easily and reliably.
2x Bosch 044 pumps into -10 is a great set-up.
And I like running large diameter fuel rails, the increased volume reduces the pulsations
in the rail caused by the injectors opening and closing.
Old Dec 4, 2010 | 01:14 PM
yes that was another plus of the larger volume rail, as i will be binning the stock anti-pulse canister. i did think about a surge tank, but im a bit stuck as to mounting it, as i cant have any fuel in the cabin, and i cant see where one would fit anywere else. i notice a lot of you guys dont run surge tanks anyway, or thats the impression i got from the "post your fuel system and questions" thread.
Old Dec 4, 2010 | 06:50 PM
cibao2ner's Avatar
i think full-race makes a -10an fuel rail...check their site..
Old Dec 5, 2010 | 10:33 AM
so anymore input guys
any of you with this setup? (no sump feeding 2x bosch pumps?)
Old Dec 5, 2010 | 11:11 AM
SPOOLINmatt's Avatar
i didn't realize sumping was a bandwagon LOL. Just sump it and be safe and sound.
Old Dec 5, 2010 | 11:27 AM
tony1's Avatar
I wouldn't call a sump 'safe and sound'. It's a horrible way to get fuel out of a short and wide tank.
Old Dec 5, 2010 | 11:37 AM
Spoolin18's Avatar
Why not purchase the FCS fuel cell with the sending unit? It's a great piece, holds 5.1 gallons and mounts in the stock tank location.
Old Dec 5, 2010 | 12:50 PM
why if theres nothing wrong with the stock tank?
Old Dec 5, 2010 | 12:57 PM
i know the shape of the stock tank is not perfect, which is why i thought a tall narrow surge tank would be the way to go, but since i cant really fit one anywhere on the car, thats out.
so im just looking for peoples actual experiance from running powerfull pumps sucking there own supply from stock location pickups, did you suffer air bubbles etc?
Old Dec 5, 2010 | 01:02 PM
Spoolin18's Avatar
The stock tank tends to rust out, etc. I'm sure the inside of your tank isn't in the best condition...no ones really is. If you use the FCS cell or any other aluminum cell it is a closed system. This is what I just did, and I run absolutely no filters. In the end, it is the better way to go.
Old Dec 5, 2010 | 01:13 PM
locash's Avatar
Absolutely no filters? I'm not sure thats something I would ever do. At the very least, one before the fuel rail.
Old Dec 5, 2010 | 01:14 PM
im putting the FCS fuel cell on this week thank goodness! Tony i agree the sump on a stock tank isn't the best thing out there for sure, ESPECIALLY for street driving lol. I hate hearing my pump starve everytime i hit the brakes even with 5 gallons in the tank.
Old Dec 5, 2010 | 03:48 PM
jdm inc's Avatar
full blown has a -10 fuel rail
http://www.fullblownmotorsports.net/...products_id/68
Old Dec 5, 2010 | 05:19 PM
gogetta's Avatar
Serious question.. has anyone ever tried shrinking the stock tank down to say 5-6 gallons.
Old Dec 5, 2010 | 06:40 PM
cotorresgee's Avatar
why not run the dual walbros? people have made plenty of good power with them. Supra guys run triple walbros and make good power as well.
Old Dec 5, 2010 | 10:13 PM
MrParks's Avatar
running into any moisture/ oxygenated fuels will rust the oem tank after being cut. you will definitely need to coat the inside of a oem tank after being modified in any way.
ive seen a coated tank after and they will never be 100% coated inside.
Old Dec 7, 2010 | 05:34 AM
hello1320's Avatar
X1000000000.
Old Dec 7, 2010 | 08:33 AM
so i take it not many people run large/twin pumps from stock pickup point then with no sump lol
Old Dec 7, 2010 | 08:34 AM
paulzy's Avatar
full blown and edelbrock both make a 10an fuel rail
Tippyman
Sep 8, 2013 01:41 PM
jsbayer
Sep 1, 2009 07:17 PM
92hondalude
Apr 15, 2009 02:57 PM
Soon_2b_evil
Apr 4, 2005 03:56 PM
