post your Fuse/Relay/EMS panels
Old 08-27-2011, 10:33 PM
  #101
dai-18t's Avatar
Default Re: post your Fuse/Relay/EMS panels
I run a pdm 30 in my set up with millspec harness. Any new race car should use one of these. It can do so so much more.
Old 08-27-2011, 10:47 PM
  #102
dai-18t's Avatar
Oh and the only switches in the car.
The pdm controls everything that is switched.
Headlights(high/low)
Rain lights
Indicators
Thermofans
vtec solenoid
60km/h pit limiter
overtake flash
brake lights
water pump
video camera/s
wipers
ecu power
dash logger power
cdi power
everything that is switched on. It is fully programable and the adl dash logs current draws for each channel and driver warning if limits are breached or something stops fuctioning.
For the money it is simply the best and very easy to install.
Old 08-28-2011, 06:14 PM
  #103
yosolo's Avatar
heres mine from STRD
Old 09-01-2011, 06:39 AM
  #104
Dynamic Performance Racing's Avatar
here is our panel that joel from speedtheory made for a customer's car
Old 02-14-2012, 09:05 AM
  #105
a1320addict's Avatar
Thought I'd share this as it's a little bit different, just finished for CLM Motorsports.
1988 E30 M3
OEM ITB, 35R to go on shortly
AEM 30-6050 (OBD2.B Honda)
AEM Twin-Fire
AEM Pencil Coil
AEM Coolant Temp
AEM Intake Air Temp
AEM 5-Bar
VAC Cam & Crank Sensors
NTK AFX
ID1000
OBD1/2 Honda IACV
Boost Solenoid
Integrated C101 connector for ignition switch, cluster, fuel relay, etc functionality.
Key is still being used for switched 12V and cranking, so a "just the essentials" was needed as a panel, fused/sealed relays for ECU/IGN, Fuel, Fan
Old 02-14-2012, 12:44 PM
  #106
$racer1's Avatar
Here's is my setup. Just picked it up. Going to have my boy richie @ Richiewerkz 5150 clean it up for me! Click on pics
Old 02-18-2012, 06:07 PM
  #107
ek9phantom's Avatar
suscribed nice stuff
Old 05-19-2012, 02:03 PM
  #108
Wanted to share some recent projects I've been involved in,
ProEFI128
Ricky Silva of CLM Motosports SFWD EK
All ready for install, rewired front to back.
Panel w/ M880, Drag4, STRD Fused Relay Box
Panel Rear w/ Aux 12V, ILL, and CAN.
Old 05-19-2012, 07:48 PM
  #109
Zer0_SpeedWorks's Avatar
I have a question when doing an ems panel together with cdi box. Does the wires/harness needs to be wrapped with shielding to avoid "noise"? Or you just need to have a individual harness for ems and cdi?
Old 05-23-2012, 03:47 AM
  #110
EP3Moschini's Avatar
where do you guys buy your deutsch connectors and pins from? I used to get them from my old work for almost free, now I have to strat to buy them. I know they are not inexpensive.
also what is the best place to buy weather pack fuses and relays?
Old 05-23-2012, 08:40 AM
  #111
redboost10's Avatar
Weatherpack stuff is available at any auto parts store.
Dt/dtm connectors at www.p-r-s.com
Old 05-23-2012, 10:58 AM
  #112
Are you asking about trigger from the EMS to the CDI or +/- to the coil?
I stock Deutsch DT/DTM/DTP connectors, solid/stamped+formed contacts, sealed relays, etc. Shoot me an e-mail if I could help you in anyway.
The above Deutsch components aren't terribly expensive, when buying through Summit/Jegs or MSD they gouge you pretty badly, lol. 9 out of 10 times, they aren't even genuine Deutsch, but "Deutsch Compatible"
Old 05-23-2012, 04:02 PM
  #113
sheepey's Avatar
the Electronics in my heap...
Old 05-23-2012, 04:26 PM
  #114
FIxALPHA's Avatar
I love my STRD harness and panel! Thanks Joel!
Old 05-23-2012, 06:11 PM
  #115
sheepey - nice! baller autosport collection you have going on . what are you logging **** or something? lol
Old 05-23-2012, 06:28 PM
  #116
sheepey's Avatar
hahaha exactly! PDM and im done...
Old 05-23-2012, 10:03 PM
  #117
We have always mounted our CDIs (pro10) in the bay to avoid noise.
Now we are going with the pro14 or drag4 and COP using cbr coils, still
undecided on weather epm or t1 trigger. But currently we have a t1 trigger in
the shop.
We want to mount the cdi in our ems panel. any tips or pointers on how to avoid
noise etc?
Thanks man! Really admire your work. I hope we have someone here in our country who can do and have materials like this. Really top notch work sir!
Old 05-24-2012, 08:10 AM
  #118
the shop.
noise etc?
I've had them mounted in the engine bay, on a panel, away from panel, etc. As long as you are using proper wiring technique and good materials, you shouldn't have an issue. Ideally, use shielded wire for Cam/Crank and Coil +/-, if you're in a bind, twisted pair for Coil +/- will generally be ok as well, use vibration mounts on the box itself.
I've found with the higher quality ignitions, the inherent problems with noise are reduced due to the quality of components being used, but if the wiring is crap...you'll most likely be chasing gremlins, lol.
You'll generally have an issue with the trigger wiring before coil wiring. I would go with the T1 trigger over the EPM for sure, T1 products are top of the line
If you have any other questions, let me know, I'd be happy to help. Thanks for the compliments!
Old 05-24-2012, 09:11 AM
  #119
sheepey's Avatar
I agree with. Joel, T1 camsensor over epm. I had a horrid misfire up top and bad rpm signal with the epm. Put the t1 sensor back on and my rpm signal is smooth with no misfire.
Old 05-24-2012, 10:37 AM
  #120
The EPM has always been hit or miss, it's nice that it's optical and all, but that's it. If we use one, it comes out of the box, gets taken apart, and then on the car.
Old 05-25-2012, 07:56 AM
  #121
So its the same as twinfire? A hit or miss thing.
I thought all you have to do is tighten the insides of the epm?
Was thinking of going that way since my topmount manifold/turbo and where the t1 trigger mounts is really tightly fitted. But never the less, we will try to mount it or have some bracket welded on the valvecover to mount the hall sensor.
Joel,will pm you soon.
Old 05-25-2012, 10:16 AM
  #122
tepid1's Avatar
So its the as twinfire? A hit or miss thing.
You have to notch the bracket. No big deal.
Old 05-25-2012, 06:40 PM
  #123
no problem with notching the bracket. We need to test fit it first.
Weve decided to go with T1 PD4 kit. With its harness, we hope to lessen the noise.
Gofast94
05-11-2014 01:03 PM
SIVIC 3
Honda Civic (2006 - 2015)
08-31-2007 11:34 AM
xtal
Honda Civic (2001 - 2005)
12-24-2006 07:51 PM
KrispyKreme
07-31-2005 06:29 PM
Angry Joe
10-13-2003 09:09 PM
Quick Reply: post your Fuse/Relay/EMS panels
