gsr final drive or ls final drive?
Old 03-17-2017, 09:19 AM
h22silvia's Avatar
Default gsr final drive or ls final drive?
looking to get your input on which final drive should I settle with if im going to put down abt 600-700 whp?
im running fully built gsr boosted. im planning to stay away from dog box and sychrotec offers 2 different final drive on carbon sychros.
Old 03-17-2017, 09:21 AM
h22silvia's Avatar
Default Re: gsr final drive or ls final drive?
btw its between a 4:40 or 4:27 and which one will give me the best benefits.
Old 03-17-2017, 09:22 AM
h22silvia's Avatar
btw im looking in between a final drive of 4:40 or 4:27
Old 03-17-2017, 10:02 AM
bajacortez's Avatar
my 2007 civic hybrid puts out 85 square feet of boost
Old 03-18-2017, 10:11 AM
b20vcrxsir's Avatar
The following information is assuming that you are using a GSR gear set.
With the 4.4 Final drive and using a 24.5" Tire:
Turning the engine to 8500 RPM you will trap 139 MPH in 4th Gear
Turning the engine to 9000 RPM you will trap 147 MPH in 4th Gear
Turning the engine to 9500 RPM you will trap 155 MPH in 4th Gear
Turning the engine to 10000 RPM you will trap 164 MPH in 4th Gear
With the 4.2 Final Drive and using a 24.5" Tire:
Turning the engine to 8500 RPM you will trap 143 MPH in 4th Gear
Turning the engine to 9000 RPM you will trap 152 MPH in 4th Gear
Turning the engine to 9500 RPM you will trap 160 MPH in 4th Gear
Turning the engine to 10000 RPM you will trap 169 MPH in 4th Gear
So depending on how high you plan on turning your engine and what trap speed you expect the car to achieve, you can make your choice!
Old 03-21-2017, 10:05 AM
h22silvia's Avatar
thanks i talk to david from sychrotech and he help me out base on my built
vinuneuro
Transmission & Drivetrain
05-29-2009 06:06 PM
MikeTV
05-14-2003 10:15 AM
Cynical 1
10-10-2002 04:05 PM
Nighthawk GS-R
04-22-2002 03:57 PM
Quick Reply: gsr final drive or ls final drive?
