Final drive gear modification.......
Old May 14, 2003 | 03:50 AM
MikeTV
Guest
Posts: n/a
Default Final drive gear modification.......
Someone correct me if I'm wrong but the final drive ratio for a stock GS-R is like 4.3 right ? Have any of you guys upgraded your final drive at all ? If so, have you noticed a big difference in acceleration ? Are there any drawbacks to doing this modification ?
Old May 14, 2003 | 04:00 AM
Regular Series's Avatar
Default Re: Final drive gear modification....... (Eclipse spanker)
FD for a GE GS-R is 4.400. A shorter (numerically larger, like 4.7 or even 4.9) will give you improved acceleration. The downsides are: lower gas mileage, more engine noise and wear, and a lower top speed (if your engine isn't built to rev higher than stock).
Old May 14, 2003 | 07:50 AM
MikeTV
Guest
Posts: n/a
Default Re: Final drive gear modification....... (Beelzebozo)
ok man thanks alot
Old May 14, 2003 | 08:34 AM
The-LS's Avatar
depend on how much power your car is putting out. Too high of a FD can make it hard to hook up on 1st gear.
Old May 14, 2003 | 10:15 AM
OBDI JEDI's Avatar
Default Re: Final drive gear modification....... (Black-LS)
i actually got better gas mileage due to the fact i was going throw the gears faster. top speed wasnt really affected i took my car up to 143 mph on the speedo with it still pulling. Basically every gear feels like the lower gear. I have no regrets about getting the FD one of my best mods.
RS_91
Aug 27, 2003 07:31 AM
Dorikamu
Jun 20, 2002 11:39 AM
R2D2
Jun 17, 2002 07:40 AM
powerfulperformance
Aug 11, 2001 03:08 PM
