Fuel set up for 600whp pump gas turbo K20 (eg).
K20a2 in an EG8. I'm starting from scratch on the fuel set up, i'll post the engine specs below. I just have 1 requirement, the pump HAS to be an in-tank unit, and i'd really like to keep the stock lines.
That being said, specs: ID2000s, petro-Can 93 gas, 6266, 60mm gate, 90mm ktuned intake manifold, aeromotive FPR, ktuned rail. Basically my question is, is there an in-tank pump that can support my 600 whp goal, with the stock lines on pump gas. To my knowledge there's the 340lph aeromotive in-tank pump, I would assume it would be sufficient. I can't out source this to a shop due to my location, or else i'd have it sumped with dual 044s.
Re: Fuel set up for 600whp pump gas turbo K20 (eg).
I have nothing against full-blown but i'm trying to keep it as plug and play as possible.
He's using a -8 A/N feed line, along with e-85. I'm trying to keep the stock hardlines and stay on pump 93. So let's say i run the walbro 450, ID2000s and use the stock hard lines I'll be able support 600+whp on pumps gas?
I made 606 whp on stock hard lines (including stock FPR, rail, and filter) with a single Walbro 255 and 1100cc injectors. This was a 2.0L gsr block in a DC2 @ 20psi on 93 octance. Obviously we were pushing the limits on the system's capabilities and reliability and I wouldn't suggest this to people as a legit option but since your looking for whats possible I figure this info would help. I DD'd this setup for a little over a year while seeing multiple track days at full power and never had a problem.
1 Post
walbro 450lph pump should be good for pump gas. but if your wanting 600hp then i would atleast throw some c16 or q16 in there for that power.
This car isn't meant to last more than a summer, big pump gas power till it blows.
Way too much here ($CAD), i'm not worried about longevity, this is just an all-out pump gas roll racer, It's got the supporting bolt ons, it should be able to. .
This concept would get you to where you need to be in the engine bay, assuming I'm understanding you correctly and are still planning on using the hardlines
https://www.youtube.com/watch?v=l_Iw1kk_7jQ
Yah, basically. I had someone message me with a link to their build thread, I'm just confirming the fitting they used to connect to the little bit of rubber hose to the fitting, that bridges the pump to the -AN lines.
Thanks for the link, I appreciate it. Thread solved.
1 Post
Just got my 4''/60mm up pipes today, there's NO way the stock filter will be fitting no matter how much I move the pipes or the filter. I've decided to use -8AN feed/return, with a single in tank unit(340 or the 450). All I need to know now is, if I can just weld a bung on where the stock feed/return lines were. And what do I use to connect the in-tank-side of the -8an bung to the pump.
Here is the best way I have found to run an lines with a Walbro 450 and stock sending unit.
JBtuned Walbro 450 hanger Mod Kit
Ohh man, you have no idea how much I wish you had posted this back in 2017! The car ultimately failed due to having bare wire exposed in the fuel tank. I ditched the build before I went up in a big fire ball all it would have taken was a short to the hanger and i'd be dead. I've since bought another shell and engine tho.
uberEFtuner
05-28-2010 10:22 PM
