LS VTEC 12.1 compression, Timing recommendations
Old 10-04-2006, 05:04 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Default LS VTEC 12.1 compression, Timing recommendations
Just wondering what you high compression guys have your timing set up as???
I have an LSVTEC 81mmx95mm fully built bottom end, p72, stock fuel setup. My timing is currently retarded all the way, it runs great, but I just want to make it run better.
Any ideas, suggestions would be greatly appreciated.
Old 10-04-2006, 05:09 AM
HamiltonRex's Avatar
Default Re: LS VTEC 12.1 compression, Timing recommendations (Kiniku Chunks!!!)
take it to a dyno and get it tuned dude. dont waste your time.
Old 10-04-2006, 05:15 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Default Re: LS VTEC 12.1 compression, Timing recommendations (HamiltonRex)
That's what I figured, thanks for the suggestion, appreciate it.
Old 10-04-2006, 11:26 AM
2'z kuztoms's Avatar
Location: Streets of Sacramento...But now living in So Cal, usa
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">take it to a dyno and get it tuned dude. dont waste your time.</TD></TR></TABLE>
x2....especially with that compression and 95 crank.btw is this your dd?
Old 10-05-2006, 04:51 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Default Re: LS VTEC 12.1 compression, Timing recommendations (2'z custom colors)
Ya, this is my DD. I got an appointment setup next WED for tuning at my shop. The guy said he could do it. I am so happy. I'll post up the dyno.
Old 10-05-2006, 10:37 AM
thats good. post up dyno sheet after you get that beast dyno. and im curious how does the the car drive dd with that 95 crank?
Old 10-09-2006, 07:47 AM
Kiniku Chunks!!!
Guest
Posts: n/a
Hey guys, I just looked this up on another thread, and the guy recommeded running some NGK spark plugs on and ls-vtec with 12.1 compression, he recommended running a colder range. the guy mentioned that it wouldn't detonate.
its under this thread
https://honda-tech.com/zerothread?id=1771274
My current timing is retarded all the way(to prevent detonation). I know I know, I am going to get it tuned wed. I'll keep you guys posted.
what do you guys think of this. One of my mechanic buddies says this is horseshit.
ed..
08-04-2011 09:56 AM
type_r_teggy
25
01-07-2009 01:45 PM
stockb18c
12-21-2008 11:56 AM
.RTErnie
11-29-2005 10:14 AM
Btothe3rdDegree
07-31-2004 01:05 PM
Quick Reply: LS VTEC 12.1 compression, Timing recommendations
