Check Engine Light -- steps to determine code?
Old 05-24-2002, 05:30 PM
I said I don't want a title!
Todd00's Avatar
Default Check Engine Light -- steps to determine code?
How do you determine what code the CEL is throwing at you? I forget the steps that one needs to do.
Thanks.
Old 05-24-2002, 05:51 PM
uNF$@#!'s Avatar
Default Re: Check Engine Light -- steps to determine code? (Todd00)
short the service connector, and coutn the blinking check engine light. long flashes = tens digit, while short flashing are the units digit.
incase you dont know what the service connector is, its near the ECU by the passenger side kickpanel. should be green with blue connectors.
[Modified by 00-0187, 9:52 PM 5/24/2002]
Old 05-24-2002, 06:02 PM
Todd00's Avatar
Default Re: Check Engine Light -- steps to determine code? (00-0187)
Do this while the car is running or with just the ignition on? I assume just the ignition on.
Old 05-24-2002, 06:48 PM
b18b98's Avatar
just the ignition.
Old 05-24-2002, 07:04 PM
StageOne's Avatar
This may help
http://www.c-speedracing.com/faq/06.html
I-4
06-05-2007 03:29 AM
h2392si
09-21-2003 08:06 AM
type Gendy
04-21-2003 04:48 PM
Quick Reply: Check Engine Light -- steps to determine code?
