DIY: Integra door handle removal/installation/change door lock
Old 07-29-2009, 09:47 PM
  #26
johnnyboy110's Avatar
Default Re: (boosted98acura)
Originally Posted by mac_24_seven
There's ya some: $124.00. I kinda like em
Those look like *****. Big old fat nasty boob. i'll motor boat um. burururuuruuur. I like
Old 07-09-2011, 08:40 AM
  #27
fuzionx23's Avatar
Default Re: DIY: Integra door handle removal/installation/change door lock
Thanks to the OP for the write up, i recently replaced the door lock cylinders couldn't have done it myself without this write up. Also take note that I live in toronto, canada. the part number i have provided may or may not be the same for USA part stores. just ask for door lock cylinder.
My 2000 Teg had door lock cylinders that were seized. I could not use my keys to get into the car. Anyhow after looking high and low a member of
your very own Toronto integras RallyHonda gave me the door lock cylinder Part Number DL74300. $50 approx.
both canadian tire and part source have this part. I ordered mine from canadian tire here at dundas/mavis canadian tire.
pics are at that link as well. the information is below.
some notes:
The one thing I can tell you is that the first time it will take you approx 30-50 minutes. It took me longer because I couldn't find the clip that held the original door cylinder to the plastic door handle. otherwise it wasn't difficult. total for both drivers side/pass side is about 1.5 hrs.
Make sure you have the right tools. As well one other note, the part where you take the door handle and remove it from the attached metal bar does not need to be removed. Its also a pain to do it.
make sure that you tape the door around the door handles or you will scratch the paint. I used painters masking tape and it did the job perfectly.
pm me if you have questions.
Old 10-18-2011, 05:20 PM
  #28
Nizmomaxine's Avatar
Good write up man it helped me out a bunch instructions were flawless
Old 09-06-2015, 02:33 PM
  #29
raverx3m's Avatar
how the hell do you get a socket in there
my glass is covering the bolts on both sides I cant get the socket on the bolt through that hole
the glass is in the way and its all the way up on both sides.
2000 integra db8
anyone else had that problem?
journeyquest
05-03-2014 08:17 PM
TeamAniki
Welding / Fabrication
12-27-2005 08:49 PM
vtec.com
06-30-2004 05:45 PM
undaunted209
01-06-2004 04:20 AM
Quick Reply: DIY: Integra door handle removal/installation/change door lock
