Crankshaft woodruff key question!
Old 02-28-2012, 03:20 PM
Slacker93eg's Avatar
Default Crankshaft woodruff key question!
I'm in the middle of rebuilding my lsvtec swap, and I'm putting the crank pulley back on.. My question is this, where should I install the woodruff key? Is there supposed to be two? One for the timing belt pulley and one for the crank pulley? I slid it in between the crank shaft and crank pulley and pushed it back as far as it could go.
Any input is greatly appreciated.
Old 02-28-2012, 03:29 PM
EK9
Dc4LsTeG's Avatar
Default Re: Crankshaft woodruff key question!
Yea there's 2 one goes on the oil pump gear and one on the crank pulley
Old 02-28-2012, 03:35 PM
Oil pump gear? Do you mean timing gear? I definitely don't remember having two come out when I took this thing apart though.. must have just dropped it only looking for one at the time. Thanks, i'll just head to acura or honda and pick one up.
appreciate it
Old 02-28-2012, 03:36 PM
TheRealTegger's Avatar
There are two keys: one for the timing-belt pulley and one for the accessory-drive pulley. One goes inside the belt pulley, one goes inside the accessory pulley. They wind up sitting end-to-end, like railroad cars.
You'll notice there is a groove in the pulley and the crankshaft. You match the two, and the key goes in the gap that results. Each key ends up flush with its pulley.
The keys are all that keep the pulleys from attempting to rotate on the crankshaft. If you're missing the belt-pulley key, you're going to wreck your engine when you try and start it. If you're missing the accessory key, the accessory-drive won't work. Both are disastrous, the first one much more so.
Old 02-28-2012, 03:41 PM
Thanks a lot. I'll get over to the dealer when I find some time I suppose. I work at a dealership that has longer hours than any other dealer I can think of lol (6am-11pm) so I'll have to make time one day. Maybe on lunch
Old 02-28-2012, 03:50 PM
EK9
Dc4LsTeG's Avatar
Oil pump gear is the timing gear
Old 02-28-2012, 03:55 PM
LightningTeg's Avatar
Yeah I dont remember putting 2 on my motor.
The timing sprocket has its own key built in that slides onto the crank. The key for the accessory pullet is seperate
Old 02-28-2012, 03:58 PM
EK9
Dc4LsTeG's Avatar
The timing gear on my b18c5 has a woodruff key exactly like the crank pulley one. Mine is not built into the gear
Old 02-28-2012, 04:29 PM
Well let's get this straightened out then.
b18b1
Order (block to crankpulley)
Timing gear with slot for woodruff
Divider plate? (circle with holes/slots in it)
Crank pulley with slot for woodruff
I do not see any sort of built in key on the timing gear.
Old 02-28-2012, 05:37 PM
There isn't one. The factory manual erroneously shows one in some diagrams.
There is a sort of dished washer on either side of the timing-belt pulley. The concave sides face AWAY from the pulley. The effect is to create a sort of funnel for the timing belt, aiming it towards the middle of the pulley.
Ordinarily you would not remove the belt pulley unless you were replacing the oil-seal that's in the oil-pump.
Old 02-28-2012, 05:57 PM
DSCF0006.jpg&w=800&h=588&ei=EpRNT6-0BcqItwfGqfWkCA&zoom=1&iact=hc&vpx=188&vpy=161&dur=361&hovh=140&
Old 02-28-2012, 06:10 PM
Old 02-28-2012, 07:02 PM
Alright this is bothering me now, so many different posts about this same situation but none of them seem to have a definitive answer.
https://honda-tech.com/forums/acura-integra-6/need-help-please-woodruff-key-crankshaft-key-way-408623/
Another post same issue. A diagram of the installation procedures to install these parts would be amazing. From what I've gathered:
[BLOCK]timing gear pulley(key)/washer/(key)crank pulley-bolt
But then there's people saying it's only ONE key needed. There is without a doubt a notch in both crank pulley and timing gear.
Old 02-28-2012, 09:40 PM
guess_who's Avatar
https://honda-tech.com/forums/showthread.php?t=408623
Notice the 2 timing sprockets are different?
The one on the left requires TWO woodruff keys. (OBD2 CFK Sensor)
The one on the right has a wood ruff key built into the sprocket (OBD1 NO CFK Sensor)
Which one do you have?
Old 02-28-2012, 10:13 PM
EK9
Dc4LsTeG's Avatar
Everyone agrees
http://www.hondapartsunlimited.com/f...T%20-%20PISTON
Old 02-29-2012, 02:39 AM
Not really sure whys its a big deal. If you have the one with 2 use both if you have 1 then dont...
Old 02-29-2012, 02:57 AM
Thank you guess who, I have the one on the left.
Old 03-31-2016, 10:28 AM
Juan Hernandez's Avatar
Hey guys I was doing valve adjustment on my 2000 integra LS B18b1 non vtec. One of my rocker arm bult from the exhaust was so tight and when loosen it the rocker arm came apart. Did I **** the engine already or do I just need to remove the exhaust camshaft and put the rocker arm back?
What should I do?
Old 03-31-2016, 11:15 AM
MotorMouth93's Avatar
lol
Old 04-01-2016, 12:28 AM
wunfstgsr's Avatar
The gear with the key built in woodfruff was from obd1which doesnt use a crank sensor, the obd2 has the star shape on the gear which gives the sensor the magnetic pick up. And theres only one key!!!! lol
tolowhb
09-20-2009 10:18 AM
Jabinya
08-28-2007 06:50 PM
twistedbydezign
09-24-2005 02:10 PM
geldingmakr
08-03-2004 10:51 AM
Kevin
05-17-2002 08:51 AM
Quick Reply: Crankshaft woodruff key question!
