93 teg shuts down randomly, problems starting
Old 08-27-2008, 04:22 PM
marshun's Avatar
Default 93 teg shuts down randomly, problems starting
ok the teg shuts down randomly. hot or cold it doesnt matter. under load or not.
also has problems starting. also hot or cold. load or no load.
things i've replaced
-main relay
-ecu
-distributor
-small black relay thats by the main relay (got it when i was lookin for a main relay. i figured its worth a shot anyway)
-small black relay near the top left section of the fuse box on the drivers side kick panel
-fuel pump
-fuel filter
-made new grounds and connected them to places on the wire harness that uses grounds. (basically making sure the grounds work without a doubt)
and now im stumped.
please help me out.
Old 08-28-2008, 04:12 AM
1ac4u2nv's Avatar
Default Re: 93 teg shuts down randomly, problems starting (marshun)
I had the same problem. Sounds very crazy, but it ended up being my alarm. The car would crank but would not start even though the alarm was disarmed. Sometimes the car died randomely while driving. do you have an alarm. Check your wiring.
Old 08-29-2008, 12:24 AM
marshun's Avatar
Default Re: 93 teg shuts down randomly, problems starting (1ac4u2nv)
no alarm on this one
i think i'll pull apart the dash tomorrow and see if theres something crazy lookin in there.
thanks for your reply though.
Old 08-29-2008, 10:15 AM
Jet Life Til' The Next Life
Byaaah!'s Avatar
Does it shut off while you are stopped?
Does it shut off while you are driving?
Old 08-29-2008, 11:49 AM
marshun's Avatar
Default Re: 93 teg shuts down randomly, problems starting (Byaaah!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Byaaah! &raquo;</TD></TR><TR><TD CLASS="quote">Does it shut off while you are stopped?
Does it shut off while you are driving?</TD></TR></TABLE>
it shuts down randomly. load or no load. its in my first post
it shuts down when im
driving
stopped
name it. it happens. i can drive for a while sometimes then it shuts off and then it wont start for a while. sometimes it shuts off and starts right back up. sometimes it shuts off right when it starts up.
it has shut down in reverse and any of the other automatic gears.
Old 08-30-2008, 07:34 AM
dalejrfan88's Avatar
Do you have an auto tranny? Ive heard of the shift solenoid causing starting problems.
Old 08-30-2008, 09:04 PM
marshun's Avatar
Default Re: (dalejrfan88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dalejrfan88 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have an auto tranny? Ive heard of the shift solenoid causing starting problems.</TD></TR></TABLE>
it is an auto and i will definitely check that one out. the money i spent trying to figure out this problem was supposed to spent on rebuilding the tranny so my brother could have a really low mileage car. i guess it'll have to wait now.
problem SEEMS to have been fixed though. my dad decided to open up the ecu and swab some parts down with alchohol. he said that there was corrosion around the circuits so he just cleaned it for good measure. so far it seems like its working.
this is the first time i've ever had to do anything like that for a honda
Old 09-13-2008, 07:19 PM
benwadb1's Avatar
I have the same problems with my db1 5 speed like it is starving for fuel, still happens randomly and occurs whenever it wants. I have replaced most of the items you have aside from the fuel pump this has been happening for 2 years now HELP
Old 09-15-2008, 10:16 PM
marshun's Avatar
Default Re: 93 teg shuts down randomly, problems starting (benwadb1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benwadb1 &raquo;</TD></TR><TR><TD CLASS="quote"> I have the same problems with my db1 5 speed like it is starving for fuel, still happens randomly and occurs whenever it wants. I have replaced most of the items you have aside from the fuel pump this has been happening for 2 years now HELP</TD></TR></TABLE>
did you even try what i said the solution was? cause the car has been working flawlessly since
Old 09-16-2008, 03:14 PM
benwadb1's Avatar
Copy that when I first got the car it needed the cowl seals replaced as the blower motor cage would fill with water and fling it all over the passenger floor board.... makes sense now thanks ill give it a shot.
ericlee303
08-24-2010 09:21 AM
EARLdaSQUIRREL
Audio / Security / Video
07-16-2008 11:12 AM
Killercarbine
12-24-2007 12:48 PM
justinsouza
03-31-2007 07:23 AM
kpop
06-24-2006 10:40 AM
Quick Reply: 93 teg shuts down randomly, problems starting
