fuel filter kill relay?
Old Mar 28, 2007 | 07:53 PM
justinsouza's Avatar
Default fuel pump kill relay?
i heard of someone doing some kind of relay on an alarm system which would basically kill the fuel pump if the alarm was armed. i have a customer with a 91 civic hb looking for added security. anyone know how this is wired?
Old Mar 28, 2007 | 08:10 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: fuel pump kill relay? (justinsouza)
I never kill the fuel pump at the fuel pump. Most theives will ripp up the seat and run 12 volts to it. It will stop the noobs but not the good theives. I like to relocate the main relay from its factory location and put it somewere else in the car, and kill it with a relay from the ground while armed wire from the brain. If its a dei alarm you will need two relays if your trying to use this way on a remote start. The reason why is that during remote start the armed while ground wire ( orange) is putting out ground while the remote start process is going on. So the second relay is needed to kill the relay thats killing the main relay.
Old Mar 28, 2007 | 08:46 PM
Default Re: fuel pump kill relay? (wrx-killer-Sti eater)
good idea, no remote start on this car, has a 350hv. do you have any schematics for this setup or a how to write up or anything?
Old Mar 28, 2007 | 10:03 PM
fcm's Avatar
fcm
Old Fart
Install the relay on the black ground wire going to the PGM-FI Main Relay, cut black ground lead connect cut ends to relays #30 and #87a, connect 12V+ true ign. to #85 and the "ground when armed" output to #86.
With that said, I would make it a redundant kill switch, not controlled by the alarm but manually, install a hidden on/off switch, the ground is low current so a small 1A switch can be used. 94
Old Mar 29, 2007 | 07:22 AM
Default Re: fuel pump kill relay? (fcm)
cool thanks. where do you normally move the relay to?
Old Mar 29, 2007 | 09:57 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinsouza &raquo;</TD></TR><TR><TD CLASS="quote">cool thanks. where do you normally move the relay to?</TD></TR></TABLE>Move the relay??? 94
Old Mar 29, 2007 | 10:29 PM
suspendedHatch's Avatar
Why do you want to kill your fuel filter?
Old Mar 30, 2007 | 01:06 AM
I put it on diffrent spots on people cars, I try to differate each main relay location. If the theif can get to the main relay and bypass it your car will start. If the relay is not in the factory easy to get to spot there is no chance of bypassing it. On the teg is on the kick pannel. on the civics its in the pass door. If you just kill it and leave it in the factory location the theif is going to find out how it is killed and do what ever it takes to get power or ground to it. Thieves just don't jump into cars and drive away. They have tools and equipment too. One that got caught in my car left one of his tools. It was a special tool made from a 12volt phone charger plug and it was tag to my fuel pump to give the fuel pump 12 volts. I tell you this it did not work thanks to the main relay kill.
Old Mar 31, 2007 | 07:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">
I put it on diffrent spots on people cars, I try to differate each main relay location. If the theif can get to the main relay and bypass it your car will start. If the relay is not in the factory easy to get to spot there is no chance of bypassing it. On the teg is on the kick pannel. on the civics its in the pass door. If you just kill it and leave it in the factory location the theif is going to find out how it is killed and do what ever it takes to get power or ground to it. Thieves just don't jump into cars and drive away. They have tools and equipment too. One that got caught in my car left one of his tools. It was a special tool made from a 12volt phone charger plug and it was tag to my fuel pump to give the fuel pump 12 volts. I tell you this it did not work thanks to the main relay kill. </TD></TR></TABLE>
ok, thanks. is the relay in the actual door or the passanger kick panel on a 91 civic?
Old Mar 31, 2007 | 07:23 AM
fcm's Avatar
fcm
Old Fart
The PGM-FI Main relay is located on the drivers side above hood release, a pain to get at, so no need to move it anyplace, it is very secure where it is... http://www.tegger.com/hondafaq...c.jpg
94
h i 9 h r 3 v z
Audio / Security / Video
Sep 27, 2012 01:35 AM
cbustuner
Mar 27, 2010 11:10 PM
Rydin
Aug 31, 2009 12:05 AM
laoboisosilly
Feb 17, 2009 05:23 PM
