2000 Civic EX Offset?
Old 05-12-2012, 06:51 PM
apocalypt1c's Avatar
Default 2000 Civic EX Offset?
Would +42 be the correct offset for 215/45/16's to fit without rubbing? Also, would I have any issues with an inch to inch and a half drop?
Old 05-12-2012, 06:57 PM
Sanji
toyomatt84's Avatar
Default Re: 2000 Civic EX Offset?
Without knowing the wheel width, its really impossible to tell. Offset is measured from the center of the wheel, so knowing its width is crucial to give any advice.
Old 05-12-2012, 07:00 PM
Sorry, forgot to include. They are 16x7.
Old 05-12-2012, 07:09 PM
Sanji
toyomatt84's Avatar
Okay, then yes, those will fit your car fine.
Old 05-12-2012, 07:11 PM
Awesome, thanks. Just one other question. What's the lowest I would be able to go on the offset while having a 1 - 1 1/2 inch drop?
Old 05-12-2012, 07:42 PM
FlewByU352's Avatar
With a drop like that you could Mexi-poke all day long. To still fit in the fender with a 16x7 you can do a +20. 16x8 +35.
Old 05-12-2012, 08:14 PM
I want them to be tucked nicely. I currently have 16x7 with a +38 offset. For the most part, they work, but I do rub when hitting bumps. It will also catch the lip on the fenders if I were to put the suspension on now.
Old 05-12-2012, 08:52 PM
Sanji
toyomatt84's Avatar
Considering there's only 4mm difference between the +38's and the +42's, and you're having rubbing issues now... you're not going to be able to go lower then the 38's.
You could easily add a tiny bit of negative camber or roll the fenders to eliminate the rubbing issues you currently have.
Old 05-12-2012, 09:14 PM
The same wheels also come with a +45 offset. Any thoughts or experiences with that offset/tire size combo?
Old 05-12-2012, 09:21 PM
Sanji
toyomatt84's Avatar
+45 would work as well, but you should be fine with +42's.
Old 05-12-2012, 09:37 PM
At least if I go with +45 in the end, I can use spacers if it ends up being too much on the positive end. Thanks for all your help.
Turbo O
02-20-2011 10:27 AM
RuDsOnEr
08-09-2008 12:14 PM
DC2_Jspec
07-15-2003 04:24 PM
Mr. Vapor
05-23-2002 09:13 AM
Quick Reply: 2000 Civic EX Offset?
