2000 Civic EX Offset?
Old May 12, 2012 | 06:51 PM
apocalypt1c's Avatar
Default 2000 Civic EX Offset?
Would +42 be the correct offset for 215/45/16's to fit without rubbing? Also, would I have any issues with an inch to inch and a half drop?
Old May 12, 2012 | 06:57 PM
toyomatt84's Avatar
Sanji
Default Re: 2000 Civic EX Offset?
Without knowing the wheel width, its really impossible to tell. Offset is measured from the center of the wheel, so knowing its width is crucial to give any advice.
Old May 12, 2012 | 07:00 PM
Sorry, forgot to include. They are 16x7.
Old May 12, 2012 | 07:09 PM
toyomatt84's Avatar
Sanji
Okay, then yes, those will fit your car fine.
Old May 12, 2012 | 07:11 PM
Awesome, thanks. Just one other question. What's the lowest I would be able to go on the offset while having a 1 - 1 1/2 inch drop?
Old May 12, 2012 | 07:42 PM
FlewByU352's Avatar
With a drop like that you could Mexi-poke all day long. To still fit in the fender with a 16x7 you can do a +20. 16x8 +35.
Old May 12, 2012 | 08:14 PM
I want them to be tucked nicely. I currently have 16x7 with a +38 offset. For the most part, they work, but I do rub when hitting bumps. It will also catch the lip on the fenders if I were to put the suspension on now.
Old May 12, 2012 | 08:52 PM
toyomatt84's Avatar
Sanji
Considering there's only 4mm difference between the +38's and the +42's, and you're having rubbing issues now... you're not going to be able to go lower then the 38's.
You could easily add a tiny bit of negative camber or roll the fenders to eliminate the rubbing issues you currently have.
Old May 12, 2012 | 09:14 PM
The same wheels also come with a +45 offset. Any thoughts or experiences with that offset/tire size combo?
Old May 12, 2012 | 09:21 PM
toyomatt84's Avatar
Sanji
+45 would work as well, but you should be fine with +42's.
Old May 12, 2012 | 09:37 PM
At least if I go with +45 in the end, I can use spacers if it ends up being too much on the positive end. Thanks for all your help.
Turbo O
Feb 20, 2011 10:27 AM
RuDsOnEr
Aug 9, 2008 12:14 PM
DC2_Jspec
Jul 15, 2003 04:24 PM
Mr. Vapor
May 23, 2002 09:13 AM
