tire size question
Old Feb 21, 2012 | 07:44 PM
jjmose03's Avatar
Default tire size question
i have a set of xxr 521 and they are 16x8 and the offset +20 is i im try to figure out what tire i can run.... my eg is dropped with neuspeed coils 2+ inches so if i could get a little input please.
Old Feb 21, 2012 | 07:59 PM
EsotericImage's Avatar
Retired Moderator
Default Re: tire size question
tire sizing is like jeans sizing..
even tho the size is the same, they have different sizes..
My experience is that Falkens run smaller except for the azenis line
Nitto's run larger on the sidewall
Kumho,BFG,Yoko seem to run true to spec..
These are based on my experiences.. but maybe others can chime in since im not into the stance fad.
Old Feb 21, 2012 | 08:11 PM
jjmose03's Avatar
thanks for the input... right now my back fender sits on my tires lol
Old Feb 21, 2012 | 08:46 PM
toyomatt84's Avatar
Sanji
The best tire setup for your car (assuming you have a '94 Civic Hatchback, non-Si... since you neglected to include the exact chassis information), as well as safe enough to fit on those wheels, would be a set of 205/40/16's. However, you're not going to be able to fit those wheels on your car without a lot of negative camber or extensive fender/quarter panel work to increase tire clearance.
Old Feb 21, 2012 | 10:09 PM
jjmose03's Avatar
you got it correct it is a 93 vx and im not lookin to tuck i just want them to go on so i can drive it
Old Feb 22, 2012 | 06:38 AM
toyomatt84's Avatar
Sanji
Well, if you're okay with doing some fender/quarter panel work, and running some negative camber... it is possible to fit those wheels with properly sized tires.
Old Feb 22, 2012 | 10:31 AM
jjmose03's Avatar
Any ideas on what tire size i should run?
Old Feb 22, 2012 | 07:42 PM
toyomatt84's Avatar
Sanji
I guess I'll highlight this part of my previous post...
Old Feb 23, 2012 | 11:31 AM
doc@tirerack's Avatar
Yep 205/40R16 is the only option we can recommend for an 8" wide wheel, but at ET20 you'll have to have some fenderwork done (even at stock ride height)....
DAGUIRRE23
May 13, 2016 09:02 AM
Naudlee
Apr 15, 2009 01:38 PM
jdmcrx_echelon
May 30, 2007 05:04 PM
bboixtc
Apr 3, 2007 07:44 AM
slammed_93_hatch
Jul 16, 2003 06:44 PM
