Redrilling bolt pattern?
Old Dec 21, 2008 | 08:47 PM
The G2 Racer's Avatar
Default Redrilling bolt pattern?
Is it possible to re drill the bolt pattern on a 5x120 rim to 4x100?
Is it safe?
Old Dec 21, 2008 | 10:45 PM
hassanbakar123's Avatar
Default Re: Redrilling bolt pattern?
Hell no!!!!!!!!!!1
Old Dec 21, 2008 | 11:27 PM
Si Trav's Avatar
Originally Posted by hassanbakar123
Hell no!!!!!!!!!!1
your just going to say no and not explain why?
Old Dec 22, 2008 | 08:11 AM
r.wright's Avatar
does the wheel have a covered cap?
i have done it several time sand nevre had problems. from 5x114.3 to 4x100 and 4x114.3 to 4x100.
the shop fills in the wheel's lug holes back and front and if the wheel has back hub pockets then they fill that in too, flatten the rear hub on a lathe and then drill a new pattern in.
Old Dec 22, 2008 | 11:17 AM
There a set of BBS RS 3 pieces and it's a damn good price for em too.
They've got flat backs so they shouldn't be to bad to get redrilled.
Old Dec 22, 2008 | 02:37 PM
r.wright's Avatar
in my experiance w/ dealing w/some machinists they feel that drilling them w/ 2 patterns such as 5x120.65 and 4x100 will weaken the wheel and make them unsafe. yes, it's less work and it can be done but is it safe to do? i'm not sure.
most jobs i have seen that way have all the holes filled then the machinist drills the wheels to the desired pattern.
Old Dec 22, 2008 | 06:12 PM
I found a local shop and they said a fill and drill would be best.
Old Dec 23, 2008 | 01:15 AM
truazn4lyfe's Avatar
jw, how much did the shop say it was going to cost?
Old Dec 23, 2008 | 05:48 AM
$100 a rim.
Old Dec 25, 2008 | 02:33 PM
Rick James's Avatar
or you could just buy some adapters they would only be like 100 each and it saves you the headache..
Old Dec 25, 2008 | 02:40 PM
From my years of wheeling I've seen way too many issues with adapters/spacers.
I won't touch them with a 10ft pole.
Old Dec 28, 2008 | 07:21 PM
Rick James's Avatar
well the adapters would be 1000000X better than redrilling.. thats just retarded IMHO
kozanatos
May 20, 2011 04:53 AM
hondateg08
Honda Civic (2006 - 2015)
Apr 9, 2009 07:11 PM
Sivic90
Sep 23, 2008 04:45 PM
loizenin
Mar 12, 2006 08:28 AM
LSVTEC 91 Civic
Welding / Fabrication
Oct 27, 2004 06:37 AM
