Modification of wheel bolt pattern
Old Oct 24, 2004 | 06:25 PM
LSVTEC 91 Civic's Avatar
Banned
Default Modification of wheel bolt pattern
Heres the deal, I'm looking for a certain style of wheels but they aren't available in the bolt pattern I need. So, here is what I am thinking.
The wheel I want has a 4 x 4" bolt pattern, I need 4 x 100mm.
4" = 101.6mm... This is what I am thinking.
I get the 101.6mm bolt pattern, and I dremel the holes out just enough to where I can get a perfect fit onto the wheel studs. Will this work? Should I spend the money and have a machine shop do this? Or should I not even bother?
Old Oct 24, 2004 | 09:02 PM
jdmteg01's Avatar
Default Re: Modification of wheel bolt pattern (LSVTEC 91 Civic)
i dont believe id mess with something like that but im not you so...
Old Oct 25, 2004 | 01:06 AM
cua0's Avatar
Default Re: Modification of wheel bolt pattern (jdmteg01)
heh, i guess its safer than plug welding your oem hubs shut and re-drilling them, i still wouldn't recommend it. haha
Old Oct 25, 2004 | 01:11 AM
turbohappy's Avatar
I wouldn't do it. depending on the style of the wheel, it could be possible to drill new holes where there are none now, but I wouldn't try dremeling out the lug holes.
Old Oct 25, 2004 | 12:36 PM
ManBearPig4silly's Avatar
If you do it no tire place will EVER touch them. They will take one look at them and tell you to go F yourself. Trust me.
Old Oct 25, 2004 | 09:10 PM
dfoxengr's Avatar
Default Re: Modification of wheel bolt pattern (cua0)
ive never heard of a standard measured wheel size. that 4x4" is your 100mm im betting. they make 4x100 and 4x105
Old Oct 27, 2004 | 03:56 AM
Banned
Default Re: Modification of wheel bolt pattern (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">ive never heard of a standard measured wheel size. that 4x4" is your 100mm im betting. they make 4x100 and 4x105</TD></TR></TABLE>
Not Centerline... the closest thing they have to 4x100 is 4x4"(101.6mm)
Old Oct 27, 2004 | 06:37 AM
dfoxengr's Avatar
what cars do those fit on. becasue ive seen many centerlines on hondas
kozanatos
May 20, 2011 04:53 AM
The G2 Racer
Dec 28, 2008 07:21 PM
loizenin
Mar 12, 2006 08:28 AM
Hybrid
Acura TL, RL & ZDX
Mar 30, 2004 03:58 AM
