Going to a 185/75/14?
I've been needing a new set of tires and I was checking out a few websites. I saw the 185/75/14 run a bit cheaper than a set of 185/70/14 (same brand - Hankook). I ran the tire sizes through the calculators and it appears to be a tire that will be roughly .75 inch taller than the factory 185/70. I have a plain jane 1995 Accord with about 240k miles and was wondering if this tire would cause me any issues other than speedometer being off a bit?
Thanks and I appreciate your opinions!
Re: Going to a 185/75/14?
I doubt it'll cause you any problems unless you are lowered. One thing you should be conscious of is that they will be a different load rating so you may need to run a different air pressure than stock. If you have a discount tire near you they will test fit the tire on your car to see if it rubs or anything for free before you purchase it.
B_1_8_hatch
39
12-08-2002 06:36 PM
