Can I use rims that are larger than stock?
On hondas i have heard that it is not safe to go over the stock rim size when switching to aftermarket rims- is this true? or is it okay to go from say a fourteen to a sixteen or fifteen?
Re: true or false?
I'd like to hear the reasoning behind this.. Why wouldn't it be safe to increase the rim size? Because that statement is false.
Re: true or false?
thats not true, however when increasing the rim size you have to be concerned about the correct tire size to use...an incorrect selection can cause numerous problems
H-T Order of Merit
Re: true or false?
Of course you can use larger diameter rims than stock! They refer to this kind of fitment as "plus one" (when it's one inch greater diameter than stock) and "plus two" (when it's two inches bigger).
However, as a general rule, the outer diameter of the tires should be approximately equal to that of the the stock tire size. This avoids the problems that H22Ej1 alluded to above, such as tires rubbing on suspension or body parts, inaccurate gauges, slower acceleration, etc.
The way the outer diameter of the tires can be equal, even though the diameter of the wheels is larger, is by choosing a tire size with a shorter sidewall. For example, if you have a car with a 185/65-14 stock tire size, it has 14" wheels, and the sidewall is 185 mm * .65 = 120.25 mm tall. The outer diameter of this size is 14" + 2 * (120.25 mm /25.4 mm/in ) = 23.47". The same car can use 15" wheels with 195/55-15 tires, for which the sidewall is 195 mm * .55 = 107.25 mm tall, but the outer diameter is 15" + 2 * (107.25 mm / 25.4 mm/in ) = 23.44".
Also, stickied at the top of this forum is a topic titled
Forum Rules and FAQ - READ BEFORE POSTING
It says:
Which is why the title has been changed from "true or false?".
It says:
Originally Posted by Forum Rules and FAQ - READ BEFORE POSTING
4a. When starting a topic, make the title specific enough that people scanning the list of forum topics will know what's inside. "Need help" or "have a question" are not specific enough. We will rename threads in ways that you might not like. If you violate this rule, we will call you a clueless tool who didn't bother reading the FAQ topic stickied at the top of this forum.
Re: Can I use rims that are larger than stock?
hey sorry about that- i dont get to the computer much now that im broke- i did scan through them briefly however did not catch that and will watch it from now on- i have a buddy in town here that is known for his street credit workin on hondas- he says it isnt safe because it puts too much strain on the axles- have always assumed this to be a personal preference of his but wanted to make sure because i have never heard it from anyone in person before- i know i have read articles in import magazine about guys preferring to use stock size rims and tires on their race cars but never really knew for sure- thank you all for your inputs!!!
Doesnt really stress the axles. Very wide wheels and tires or low offset wheels put stress on the wheel bearings. Huge heavy wheels can wear out suspension components faster. But as long as you keep the overall diameter as close to stock as possible like nsxtacy said, its ok. Going a little wider than stock and an inch or two bigger is no problem and is usually beneficial for performance, assuming youre using a fairly lightweight wheel and sticky tires.
H-T Order of Merit
An inch and especially two can be a big problem for rubbing. Going 10-20 mm wider is usually no problem. Performance benefits are usually pretty small; the big factor in performance benefits is in the availability of stickier tires, which can go either way.
