2006 acura tl offset question...
i was wondering if this set up for my 2006 acural tl will fit or not (Front 18x7.5 +44 Rear 18x8 +44) and if it will clear the calipers?? or rub? i know thw size will but not sure about the offset. Please help. thanks
Re: 2006 acura tl offset question... (DagreenEK)
as far as not rubbing: i think you should be fine.....although, staggered wouldn't be my first choice for fwd but yeah, you should be okay but just don't go crazy on tire sizes..
235/40 all around
as for brake clearance: just ask the seller to measure the back hub then do some measuring of your own..here is a link i like to use for this :
https://www.rsracing.com/tech-wheel.html
235/40 all around
