Solid mounts DIY
Old Mar 6, 2005 | 07:38 PM
  #26
turbo gli's Avatar
Default Re: SOLID MOUNTS DIY (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianDelSol &raquo;</TD></TR><TR><TD CLASS="quote">Which mounts do you do? All 5 of them?</TD></TR></TABLE>
do all the mounts . i dont see y u wouldnt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianDelSol &raquo;</TD></TR><TR><TD CLASS="quote">I am gonna attempt the front lower mounts and the trany mount or whatever is in that link over spring break. I will photo document it, let everyone knoe how it went. Can you get that **** at home depot or something?</TD></TR></TABLE>
**** no home depot dont sell this **** .. the 3m stuff they do .. but not the 2part poly mix
Old Mar 6, 2005 | 08:16 PM
  #27
BrianDelSol's Avatar
Default Re: SOLID MOUNTS DIY (turbo gli)
Thanks for the info, where can you get the McMaster stuff, I'd prefer not ordering it unless I have to.
Old Mar 6, 2005 | 08:39 PM
  #28
turbo gli's Avatar
Default Re: SOLID MOUNTS DIY (BrianDelSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianDelSol &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info, where can you get the McMaster stuff, I'd prefer not ordering it unless I have to.</TD></TR></TABLE>
online is the only place man .. dunno of any stores that would carry this stuff ..
Old Jun 10, 2006 | 06:32 PM
  #29
Dulluthkid_19's Avatar
I know this thread is old but can somebody explain to me WHY is seems to be that people worry so much a little air bubbles in their poly mix? I mean, sure I understand the concept of it but does it really matter if there are a bit of air bubbles - honestly.
BTW, I filled my torque mounts with PL Concrete Crack filler (polyurethane), I have no idea how hard it's going to be, but I suspect it may be harder than I anticipated lmao...
I should have filled it in steps, maybe it wont cure all the way, I might have to drill holes.
Old Jun 11, 2006 | 10:26 AM
  #30
Default Re: SOLID MOUNTS DIY (Dulluthkid_19)
bump! Can somebody tell me?
Old Jun 13, 2006 | 09:36 AM
  #31
pumafeet10's Avatar
is ther eanyone that can tell me exactly to look on mcmaster cuz there is a lot of stuff under flexible urethane im jsut not sure whihc one we are talking about exactly . I need to fill the mounts on my accord asap! Thanks
Old Jun 13, 2006 | 11:21 AM
  #32
chitownrida's Avatar
i dont have a problem with my window weld.. works fine..
maybe too soft for the hardcore people though
Old Jun 13, 2006 | 06:51 PM
  #33
pumafeet10's Avatar
Default Re: SOLID MOUNTS DIY (pumafeet10)
i need to fill mine since i will be removing one of mine so i can turbo my accord so i need to find out where to get it from mcmaster!!! HELP!!
Old Jun 13, 2006 | 08:44 PM
  #34
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumafeet10 &raquo;</TD></TR><TR><TD CLASS="quote">is ther eanyone that can tell me exactly to look on mcmaster cuz there is a lot of stuff under flexible urethane im jsut not sure whihc one we are talking about exactly . I need to fill the mounts on my accord asap! Thanks</TD></TR></TABLE>
OK, go on http://www.mcmaster.com/ and you see the tabs on the upper-left side of the page that says "Find Products" and "Build Order". Click on the "Build Order" tab and in the "Item" box enter the part number for the 60A Flexible Urethane which is 8644K24. Enter in your Quantity in the Qty box and then go down and click "Add".
It will load up and tell you what you have in your cart, look down and click on the "I am new to this web site." option and the page will reload and let you fill in your information for billing and shipping.
Sorry for dumbing this down, but I am ******* bored
Old Jun 13, 2006 | 10:53 PM
  #35
pumafeet10's Avatar
no man i just was to hyper when i read this post to look for real and was hoping someone would dumb it down for me. Thanks again i really appreciate the time you took! Thanks man!
David
Old Jun 14, 2006 | 01:44 AM
  #36
raceACCORDingly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dulluthkid_19 &raquo;</TD></TR><TR><TD CLASS="quote">I know this thread is old but can somebody explain to me WHY is seems to be that people worry so much a little air bubbles in their poly mix? I mean, sure I understand the concept of it but does it really matter if there are a bit of air bubbles - honestly.
cuz then its not really solid and allows for flex.
look it up on mcmaster by part #. 8644K11 is the 80a shore stuff that i used.
Old Jun 14, 2006 | 11:20 AM
  #37
Jamez's Avatar
Default Re: SOLID MOUNTS DIY (raceACCORDingly)
I just want to add something I've discovered lately about reducing vibration. Provided you only did the bottom 2 (which are really the only ones worth doing) all you need to due to stop vibrations at idle is remove the nut from the engine lower mount.
The engine is not going to fall off from that single nut missing since it's held by 4 other mounts and the flimsy lower mounts never really supported the engine in the first place.
Not being directly connected to the mount keeps the engine from rattling the car to pieces at idle. However under acceleration and shifts the solid mount still keeps excess engine motion in check. Best of both worlds
Old Jun 15, 2006 | 02:32 AM
  #38
b_ron007's Avatar
i filled my accords front and rear motor mounts with 3M window weld, and thats going past 3 years now. the difference was very noticeable, my engine doesn't even rock, and still to this day the mounts look just as good as the day i did it. just my .02
Old Jun 15, 2006 | 09:49 AM
  #39
pumafeet10's Avatar
Default Re: (b_ron007)
See for me i am going to be going turbo on my accord and am getting an equal length mani and there is no way for me to keep my front mount. So i am going to fill the mounts and hope that they are strong enough to keep the motor from rocking or damagine the other mounts. also found out that innovative makes track mounts for the accord os im nto sure what i will do the factory mounts look like crap, so thats why i might go innovative
Old Jun 15, 2006 | 10:07 AM
  #40
turbohappy's Avatar
Default Re:
I did all the mounts on my CRX/Civic about 4 years ago, haven't had any problems. I cut up a small 100% polyurethane cutting board to fill the big gaps and then filled the small gaps with the Windo Weld. VERY stiff and I didn't have to worry about it not drying. Windo weld was $7 and the cutting board was like 75 cents.
Old Jun 15, 2006 | 02:43 PM
  #41
Default Re: Re: (turbohappy)
^^^ That's a pretty cool idea. Man I can't believe the **** I posted a year ago, takes me back...
James777
Nov 4, 2010 11:57 AM
HAMOTORSPORTS
Performance
195
Apr 20, 2010 10:21 AM
smokey.23
22
Mar 24, 2009 09:01 PM
sittin on GOLD
Jan 3, 2009 09:22 PM
SkRiBLaH
10
Mar 2, 2005 07:41 PM
