sequential shifter
Old Oct 21, 2004 | 07:06 PM
  #51
Nameless RB26's Avatar
Default Re: sequential shifter (ProstockH22crx)
I'm getting the Ikea shifter for my 240.
Sucks for you Honda dudes...
Old Oct 21, 2004 | 10:32 PM
  #52
b16hybridsol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProstockH22crx &raquo;</TD></TR><TR><TD CLASS="quote">Ricky dela Cruz's hot rod crx has a Longs shifter attached to his stock shifter cables. Instead of the H pattern, he just shifts up and down, but still uses clutch. We'll be in Pomona if anybody wants see it in person.</TD></TR></TABLE>
pics please i'm in oh
Old Oct 22, 2004 | 06:26 AM
  #53
MidShipCivic's Avatar
Default Re: sequential shifter (Nameless RB26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless RB26 &raquo;</TD></TR><TR><TD CLASS="quote">I'm getting the Ikea shifter for my 240.
Sucks for you Honda dudes...</TD></TR></TABLE>
they have one just not out .
Old Oct 22, 2004 | 07:35 AM
  #54
hypercivic's Avatar
Avid Racing makes an H22A race shift linkage and they recently dropped their price on them. I am a dealer for them Florida. Check them out at http://www.avidracing.com Don't mind their current price on the web, they have dropped it... Hope that helps you.
Old Oct 22, 2004 | 11:31 AM
  #55
h22 civic's Avatar
Default Re: (hypercivic)
their alot involved in the avid linkage also no passenger seat,heater core ive heard the mount gotto be changed any solid fact what needs to be done to get this avid linkage to work i got pics of it in a eg i need it for a ek
Old Oct 22, 2004 | 03:13 PM
  #56
Default Re: sequential shifter (MidShipCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">
they have one just not out . </TD></TR></TABLE>
Exactly.. so sit on your *** and wait for it.
Old Oct 23, 2004 | 02:10 AM
  #57
Exactly.. so sit on your *** and wait for it.</TD></TR></TABLE>
LOL I don't need to wait I'm fine with straight cut gears and the H pattern NISSAN BOY No lift shift!
Old Oct 23, 2004 | 11:16 AM
  #58
Junior_r's Avatar
Default Re: (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">their alot involved in the avid linkage also no passenger seat,heater core ive heard the mount gotto be changed any solid fact what needs to be done to get this avid linkage to work i got pics of it in a eg i need it for a ek</TD></TR></TABLE>
could you post the pics please?
Old Oct 23, 2004 | 03:40 PM
  #59
ouch, a nissan punch below the belt.
Right.. enjoy that FWD sequential.
Old Oct 24, 2004 | 04:44 PM
  #60
h22 civic's Avatar
Old Nov 1, 2004 | 03:45 PM
  #61
h22 civic's Avatar
Default Re: sequential shifter (h22 civic)
keep it alive
Old Nov 1, 2004 | 05:32 PM
  #62
You can only have a Seqential Forward /backward shift, gearbox H pattern will never work and in racing they use electric solenoids like this : http://www.quickshifter.net/buttonshifter4.htm
Old Nov 2, 2004 | 03:07 PM
  #63
.nate's Avatar
$1100USD for that thing too... hmm It could be replicated with some work...
Old Nov 2, 2004 | 05:52 PM
  #64
trbcivic's Avatar
Default Re: (.nate)
keep this alive
Can some tell me more about the Avid H22 Shifter?
Old Nov 9, 2004 | 05:37 PM
  #65
h22 civic's Avatar
Old Nov 9, 2004 | 06:15 PM
  #66
xci_ed6's Avatar
ideas....
For a simple non-sequential system to prevent mis shifts a simple ratchet system could be used. Unfortunatly you would have to release the ratchets to downshift.
For the clutch, everyone is looking at it wrong. What you need to do is operate the hydraulics, not the clutch lever. A ABS type system could be used with variable valveing for smooth/rough clutch engagement.
For a true sequential system you could use something with 4 drums, 2 rotating, 2 fixed. Picture it one pair at a time. You have a fixed drum that the cable is atatched to, and one that the lever is atatched to. The rotating drum has the shift pattern for either l-r or f-b cut into its surface. as it rotates against the other drum it is forced in and out, moving the cable. Then a simple bearing system would be used to ratchet back to center. The same could be done with a single drum with two patterns cut into it that levers operating the cables work through.
These could be aplied to even lever shift trans missions useing a similar system as is used when putting a b18c into an elise.
Old Nov 9, 2004 | 06:42 PM
  #67
xci_ed6's Avatar
Default Re: sequential shifter (krustindumm)
this will have to do until i get a confirmation email from we_todd
neonkid
Honda Civic (2006 - 2015)
Mar 7, 2014 05:57 PM
88rexA6
Welding / Fabrication
36
Jan 6, 2011 12:17 PM
bigsnorlax
Sep 11, 2008 02:57 PM
O RLY
Oct 17, 2006 06:25 AM
kb7709
Dec 27, 2004 03:04 PM
