sequential shifter
Old Sep 18, 2004 | 10:51 AM
  #26
b16hybridsol's Avatar
Default Re: sequential shifter (ZoRG)
ohhh ok
Old Sep 19, 2004 | 07:44 PM
  #27
FF lotus's Avatar
Default Re: sequential shifter (b16hybridsol)
They do make sequential gearboxes for Hondas I had this on a car a couple years back and it cost me 5K used and they go for 10K new. I sold the car and the current owner beats on it occasionally and says it's still in one piece
http://www.quaifeusa.com/
Old Sep 20, 2004 | 01:55 AM
  #28
ZoRG's Avatar
Default Re: sequential shifter (FF lotus)
I think its closer to 15-20K not many people can afford that.
Old Sep 20, 2004 | 10:19 AM
  #29
yea, must be nice
Old Sep 20, 2004 | 11:49 AM
  #30
R-Toyz.com's Avatar
I saw an install feature in Option2 way back in 97 on something that I think mimics the up/down movement of a sequential shifter. Its a metal frame with springs that bolts on top of the stock shifter and guides the shifter itself as you push it through the gears. All you have to do is push or pull the lever and you should go thru the gears more smoothly. It ain't a sequential, but it will help eliminate missed shifts...i'll scan some pics and post them.
Old Sep 20, 2004 | 04:11 PM
  #31
FF lotus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZoRG &raquo;</TD></TR><TR><TD CLASS="quote">I think its closer to 15-20K not many people can afford that.
No it's 10K not 15-20K
It's worth it when buidling any car that allows it. You get a lifetime warranty on many parts and it's really no more expensive than a couple seasons transmission builds.
Old Sep 20, 2004 | 06:41 PM
  #32
H22EK9's Avatar
Ok, well since there are now a few answers to the shifting part, what about clutch engagement. What is used in a F1 application. How could the clutch be disengaged (if there is a clutch) while selecting a gear. This **** should be thought of it would be badass, even if it is not economical. I would do it in a heartbeat.
Old Sep 20, 2004 | 06:46 PM
  #33
FWDrag's Avatar
Ive seen a yellow Honda CRX driven my Ricky dela Cruz in the import drag racing series that has a pretty trick shifter. Hes still running the factory honda tranny and it is still shifted in the H pattern. The shifter is like a slapper style used on sequential trannies but was customized to work with the honda trans. You still must engage the clutch with your foot but the problem of missed shifts are gone. No more 2-3 missed shifts, just an up and down shift. I liked the idea and may use that design on my own race car. The best thing about it, probably cost no more than a few hunderd bucks.
Old Sep 20, 2004 | 10:37 PM
  #34
Default Re: sequential shifter (FWDrag Inc)
i was planning on still using foot engagement for the clutch, the sequental shifter from ikeya is exactly what you are talking about, but they want around 1500 for it, which is why i'm trying to make one
Old Sep 21, 2004 | 08:02 AM
  #35
ZoRG's Avatar
Default Re: sequential shifter (H22EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22EK9 &raquo;</TD></TR><TR><TD CLASS="quote">Ok, well since there are now a few answers to the shifting part, what about clutch engagement. What is used in a F1 application. How could the clutch be disengaged (if there is a clutch) while selecting a gear. This **** should be thought of it would be badass, even if it is not economical. I would do it in a heartbeat.
Dog engagement. You don't use the clutch to shift, just to pull away and stop.
Old Sep 21, 2004 | 08:26 AM
  #36
ZoRG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FF lotus &raquo;</TD></TR><TR><TD CLASS="quote">
It's worth it when buidling any car that allows it. You get a lifetime warranty on many parts and it's really no more expensive than a couple seasons transmission builds.</TD></TR></TABLE>
Unfortunately still out of my pricerange, but not bad if you have the cash and wan't something unbreakable...
Old Sep 21, 2004 | 10:42 AM
  #37
Silverpike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol &raquo;</TD></TR><TR><TD CLASS="quote">i was planning on still using foot engagement for the clutch, the sequental shifter from ikeya is exactly what you are talking about, but they want around 1500 for it, which is why i'm trying to make one</TD></TR></TABLE>
That is hot ****. I am an H-series owner, and I know many people that would kill for something like this. I would love to see something like this made.
Bump for a cool *** project.
Old Sep 21, 2004 | 11:48 AM
  #38
Default Re: sequential shifter (Silverpike)
fabrication will start within the next week, i've got 50 million dimensions all drawn out, and it works on paper ha, we'll see what happens
Old Sep 21, 2004 | 05:47 PM
  #39
H22EK9's Avatar
Dog engagement. You don't use the clutch to shift, just to pull away and stop.</TD></TR></TABLE>
So your moving and want to upshift, you just tape down on shifter without using clutch and it goes into gear okay? And vise versa on the downshft, with rev matching of course.
Old Sep 21, 2004 | 11:56 PM
  #40
ZoRG's Avatar
So your moving and want to upshift, you just tape down on shifter without using clutch and it goes into gear okay? And vise versa on the downshft, with rev matching of course. </TD></TR></TABLE>
yes. you have a switch on the gearlever that cuts ignition/fuel when you shift. Have you ever ridden on a bike? exact same thing ... you don't need to use the clutch to shift.
Old Sep 22, 2004 | 04:03 AM
  #41
H22EK9's Avatar
So what if you want to do this to a honda and you have the sequential tranny. You would just have to come up with some type of fuel/ignition cut devive and you would have clutchless shifting?
The reason I am so interested is I will shortly have an S2000 and it would be much easier to mate a tranny to a FR car than a FF, and I would love to have this in my car.
Old Sep 22, 2004 | 06:33 AM
  #42
ZoRG's Avatar
If its a true sequential with dog engagement yes, if its the system thats been suggested here, no, then you still need the clutch.
Old Sep 23, 2004 | 03:27 PM
  #43
Curtisbeef's Avatar
here is some video of it working
http://www.errordownloadingcod....mpeg
Old Oct 17, 2004 | 04:26 PM
  #44
h22 civic's Avatar
Default Re: (Curtisbeef)
what happen to this thread any progress??? this has to happen
Old Oct 17, 2004 | 04:57 PM
  #45
Default Re: (h22 civic)
i got distracted ha, i'm gettin ga new welder, and i have been taking my car apart, i'll get back to it soon
Old Oct 17, 2004 | 05:06 PM
  #46
MidShipCivic's Avatar
http://www.takakaira.com/perfo....mpeg
Ikeya shifter very short vid.
Old Oct 20, 2004 | 05:05 PM
  #47
h22 civic's Avatar
Default Re: (MidShipCivic)
Old Oct 20, 2004 | 08:08 PM
  #48
kb58's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curtisbeef &raquo;</TD></TR><TR><TD CLASS="quote">here is some video of it working
http://www.errordownloadingcod....mpeg</TD></TR></TABLE>
I want to get a frozen trout and smack the "cameraman" who can't hold the f*cking camera still. This isn't MTV... and the result of this fine video is exactly nothing because no one can see WTF is going on. Time to take my meds...
Old Oct 20, 2004 | 08:40 PM
  #49
Default Re: (kb58)
haha totally hear that, i wish i could see how the gears attach to the cables then i'd be set
Old Oct 21, 2004 | 04:09 PM
  #50
h22 civic's Avatar
Default Re: (b16hybridsol)
come on hombre get set we neeeedz dis
