SEARCHED! Anyone using 1/4 turns to mount bumper???
Hey guys, I wanted to know if anyone used 1/4 turn fasteners to mount there bumpers on...How did you do it?? Any pics?? I know full-race geoff mounted his bumper on with them ...Thanks guys!!!
Re: SEARCHED! Anyone using 1/4 turns to mount bumper??? (Hondatuner88)
vtekthis & boostfed have theirs on this way as well. maybe you can get them to post some pics. its a simple bracket. i belive moroso makes the kit with the mounting bracket..
these what you are talking about? there are many different styles
http://www.milspecproducts.com/z-lock.htm
Re: SEARCHED! Anyone using 1/4 turns to mount bumper??? (josh green)
I used to use Dzus fasteners all the time. They are easy enough to use if you can use a rivet gun.
Re: SEARCHED! Anyone using 1/4 turns to mount bumper??? (beepy)
Yeah some pics would really help me out....thanks guys and yes those are the ones...
here it is...
pop rivet this to the bottom of the fender(where your bumper normally bolts on)
90° Quick Fastener Mounting Bracket, Steel, For Use With 1'' & 1-3/8'' Springs, 10/Pkg.
710-71552
then just mount this in your bumper
710-71552
Re: SEARCHED! Anyone using 1/4 turns to mount bumper??? (dturbocivic)
do fasteners like these hold up to all the vibrations, etc?
do the 710-71370 springs go with the 710-71552 brackets?
I have had this problem plague me forever and this looks like a nice fix.
Re: SEARCHED! Anyone using 1/4 turns to mount bumper??? (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 »</TD></TR><TR><TD CLASS="quote">do fasteners like these hold up to all the vibrations, etc?
I have had this problem plague me forever and this looks like a nice fix.</TD></TR></TABLE>
yes they work well. just have to get the spring tension correct, so the fastener gets tight. if its loose or whatever, it wont work well.
as for XX springs with XX brackets, i cant tell you. when i order stuff like this i always tell them i need XX brackets or XX fasteners & springs etc to match..
it also keeps the bumper nice and tight to the fender. help get rid of that ugly gap...
for the spring tension is it just as simple as fooling around with it when its almost assembled to determine the correct tension?
when installing, I take it that you mount the bracket first, push the bumper flush against the fender, and mark the back side through the bracket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 »</TD></TR><TR><TD CLASS="quote">for the spring tension is it just as simple as fooling around with it when its almost assembled to determine the correct tension?
when installing, I take it that you mount the bracket first, push the bumper flush against the fender, and mark the back side through the bracket?</TD></TR></TABLE>
yes and yes...
here is the correct kit so you arent mixing and matchin parts.
Heavy Duty Hood and Deck Installation Kit
555-82270
yes and yes...
555-82270
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">yes and yes...
555-82270 [/B]</TD></TR></TABLE>
sorry if i sound like a moron, but what site is that pn# off of? i looked on that milspec link above, but no go.
Re: SEARCHED! Anyone using 1/4 turns to mount bumper??? (jarel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jarel »</TD></TR><TR><TD CLASS="quote">
sorry if i sound like a moron, but what site is that pn# off of? i looked on that milspec link above, but no go.</TD></TR></TABLE>
http://www.jegs.com
i think they might sell a "smaller kit" which comes with 2 tabs,2 springs, and 2 buttons.. that one i posted up higher have 10 of each, which is simply way too many.
http://www.jegs.com
hooray for Dzus fasteners. It's pronounced "Zues" too, i had to look it up online, i was sick of being unsure of how to say it.
