Mounting Precision Medium FMIC
Old Oct 25, 2005 | 09:28 PM
JDM00SI's Avatar
Default Mounting Precision Medium FMIC
So ive started my project....i have a precision medium FMIC, although im sure most of you guys know that it does NOT have tabs to mount it...what a pain up the ***. although there are 2 holes on each side of the end tank for a stud to go through..... hmm...i was thinking about finding the size of that stud...put it in. After that weld that stud onto the bumper or weld that stud to a bracket that is mounted on the bumper...
those of you w. FMICs without Tabs....please post pics of your set up or give me some ideas...
Thanks
Old Oct 25, 2005 | 09:31 PM
JDM00SI's Avatar
Default Re: Mounting Precision Medium FMIC (JDM00SI)
quick bump before i go to sleep
Old Oct 26, 2005 | 04:49 AM
SSBPGSR's Avatar
i had so many pictures of how i mounted mine but my computer crashed. its real hard to explain, but i used L shaped brackets, some cut dirtbike handlebars and some bolts. had to cut my bumper support to make this work though. ill see if i can find some pictures on my brothers computer and get back to you.
Old Oct 26, 2005 | 04:55 AM
SSBPGSR's Avatar
Default Re: Mounting Precision Medium FMIC (SSBPGSR)
found one but you cant really tell how its mounted, but this gives you an idea of how you will have to cut the bumper support
Old Oct 26, 2005 | 06:28 AM
JDM00SI's Avatar
thanks anyone else?
Old Oct 26, 2005 | 06:35 AM
11SEC CIV's Avatar
Default Re: (JDM00SI)
i had the same problem w/ my fmic and have it mounted differently...this looks like it would work fine/ and simple to install
hope this helps
Modified by 12SEC CIV at 5:59 PM 10/26/2005
Modified by 12SEC CIV at 10:05 PM 10/27/2005
Old Oct 26, 2005 | 06:39 AM
SSBPGSR's Avatar
Default Re: (12SEC CIV)
^^^ exaclty what i used, except i mounted it to the bumper support. i just cut out peices of a hollow tube ( dirtbike handlebar ) to put between the bracket and the bumper support. so when i tightened down the bracket it didnt bend upward or rip out the threads on the intercooler itself.
Old Oct 26, 2005 | 06:44 AM
B18Flip's Avatar
Default Re: (SSBPGSR)
i was too lazy to cut my support beam so i took it off, used the 2 bolt holes on each side, bolted up a stainles plate and mig welded support bars that boled to the fmic.
Old Oct 26, 2005 | 07:45 AM
EJ8Joel's Avatar
Default Re: (B18Flip)
I welded two 90 degree tabs on the top of mine, and cut about 2" out of the bottom of the bumper support, and hung it from there with some SS hardware. I wanted to keep my support as intact as I could, and that let me do it without completely ditching it.
Old Oct 26, 2005 | 09:13 AM
JDM00SI's Avatar
Default Re: (JDMJoel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJoel &raquo;</TD></TR><TR><TD CLASS="quote">I welded two 90 degree tabs on the top of mine, and cut about 2" out of the bottom of the bumper support, and hung it from there with some SS hardware. I wanted to keep my support as intact as I could, and that let me do it without completely ditching it.</TD></TR></TABLE>
i like the idea anyone else with mnore ideas?
Old Oct 26, 2005 | 10:08 AM
dnbruut's Avatar
if it fits into the original bumper"mouth" why not drill little holes into the ic lowest and top plate and use screws to screw it into the bumper? (that is if your ic doesn't weigh a ton!)
Old Oct 26, 2005 | 11:07 AM
JDM00SI's Avatar
weighs way too much to bolt in bumper
Old Oct 26, 2005 | 01:04 PM
dnbruut's Avatar
your bumper wont fall off!
Old Oct 26, 2005 | 01:08 PM
MooreBoost's Avatar
Default Re: (dnbruut)
Old Oct 26, 2005 | 01:16 PM
dnbruut's Avatar
Default Re: (MooreBoost)
ok now weigh that ic and feel how strong the original bumper is. its very strong in the "mouth" at least my delsol is and it fits mine perfectly
Old Oct 26, 2005 | 02:05 PM
EJ8Joel's Avatar
If your bumper is holding up your IC, you're asking for it. Bumps, train tracks, everyday driving will make that thing bounce if it isnt bolted to the car. Couplers will loosen and fall off, if not tear. Just a dumb idea, take your time and bolt it. Either use the holes on it, or make some tabs.
Old Oct 26, 2005 | 03:51 PM
blackANESE's Avatar
My old car
Cut the support and welded in custom tabs inside the support to bolt the intercooler to
Old Oct 26, 2005 | 05:55 PM
JDM00SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SEC CIV &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem w/ my fmic and have it mounted differently...this looks like it would work fine/ and simple to install
hope this helps
Modified by 12SEC CIV at 5:59 PM 10/26/2005</TD></TR></TABLE>
wow...now thats a good HT member, Thanks ALOT im going to do the same exact set up, i will remove bumper support, damn thanks man.
Old Oct 26, 2005 | 06:11 PM
JDM00SI's Avatar
i also realized that im gonna have to loose the foglights for this set up
Old Oct 26, 2005 | 07:58 PM
Scracho's Avatar
hope this helps
Creativity... Some basic brackets and presto insta-FMIC! I love those intercoolers... MMmmmm... Cast end tanks, thick bar and plate construction...
Old Oct 26, 2005 | 08:08 PM
EJ8Joel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM00SI &raquo;</TD></TR><TR><TD CLASS="quote">i also realized that im gonna have to loose the foglights for this set up</TD></TR></TABLE>
You may not have to. If you turn the fmic so the endtanks have the holes facing up, or oppisite of how all these pics show, you may be able to route the piping over the fog lights. There is a thread about it somewhere, try searching for a while, I know its out there.
Old Oct 27, 2005 | 03:03 AM
dnbruut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJoel &raquo;</TD></TR><TR><TD CLASS="quote">If your bumper is holding up your IC, you're asking for it. Bumps, train tracks, everyday driving will make that thing bounce if it isnt bolted to the car. Couplers will loosen and fall off, if not tear. Just a dumb idea, take your time and bolt it. Either use the holes on it, or make some tabs.</TD></TR></TABLE>
have got flex pipes
Old Oct 27, 2005 | 04:46 AM
LShatchie's Avatar
my buddy mounted his with industrial zip ties, the ones that are 3 feet long... he took 2 and put them together making them 6 feet and tightened the **** outta them... that intercoolers going no where, kinda cheap tho
Old Oct 27, 2005 | 06:21 AM
null.'s Avatar
Default Re: (LShatchie)
did the exact same thing as SSBPGSR
Old Oct 27, 2005 | 10:18 AM
yee SERIOUS's Avatar
you should contact honda heaven. i think they did CTRbOy's ic piping to fit fog's.
http://www.h-heaven.org/
