Pre-drilled rectangular steel tubing
Hello all,
I am in need of a bit of help here. I have a project that requires a bunch of 2" x 1" rectangular steel tubing with 3/8" holes punched every 1 inch. I attempted to do this on the drill press, but it is taking too much time to get anything remotely accurate. Does anyone know of a place that I can order it from?
Thanks..!
Thanks..!
Re: Pre-drilled rectangular steel tubing (parasonic)
Depending on what the intended structural use is going to be, what about some pre-made shelving supports? Just what came to my mind first.
Re: Pre-drilled rectangular steel tubing (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">a machine shop would bang that out quick on a mill.</TD></TR></TABLE>
truth. although it may cost a lot more then u would like. but its defitnatly worth a try if you want acuracy
http://www.mcmaster.com has 1x1 and 2x2 on page 3554
If those won't work, try some of these:
http://www.centralsteel.com
http://www.ryerson.com
http://www.macsteel.com
http://www.phoenixmetals.net
http://www.marmonkeystone.com
http://www.emjmetals.com
Good luck!
Good luck!
Vitt1
09-20-2004 07:49 PM
