pipe bender ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">where does the oil come from if there is no reserve tank?</TD></TR></TABLE>
There is actually a reserve tank, it just doesn't look like a tank. The piston is single acting. Which means the oil pushes it out, and you push it back in. At least on my jacks the piston is like 2 or 3 inches in diameter, and the piston cylinder is the same 3 inches in diameter. If you notice the outside diameter of the jack is like 6 inches in diameter. That area in between is your oil storage tank. It is the area between the two coaxial cylinders. Sort of neat how they hid it!
Here's a 1 1/2 inch to 2 incher for $27K http://www.hinesbending.com/150nc.htm
3 inch bender for $28K http://home.flash.net/~dgjco/N...0.htm
2 and 3 incher for $40K http://www.hinesbending.com/200nc.htm
3 to 4 incher for $50K http://www.hinesbending.com/300nc.htm
Great primer on bending pipe and tubing: http://www.hinesbending.com/Tu...e.htm
Here is the quality of the bends:
Modified by BigMoose at 6:47 PM 8/20/2005
Modified by BigMoose at 7:32 PM 8/20/2005
Old school way....
What I used to do in the past is get two drum brakes and clamp them down to the table with bunch of C-clamps. Take a "rose-bud" and heat up the portion of the pipe you want to bend and slowly bend around the drum brakes till you get to the angle you want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER »</TD></TR><TR><TD CLASS="quote">Not to be a dick, but its junk. In order to bend piping for ic and that sort of uses you need a mandrel bender which will run you around 70k.</TD></TR></TABLE>
Hell yeah!!
Hell yeah!!
That's a nice image of a true mandrel tube bender, simular to what I use which includes a collet, all the axes servo's and all the necessary dies. for 70k looks pretty good compared to the 500k that I use, eagle
, oh yea btw.. for whomever is interested in bending tubing w/ a mandrel, it's not easy.. there's a lot of troubleshooting that goes a long w/ it, and theory on how a mandrel bender works, trust me you can ruin a really expensive machine easily so make sure you understand the basics on how everything works before tackling a job. I've bent the rod due to putting the mandrel foward and it hit the c axes servo arm, broke plenty of bend ***** do to unproper alignment, I think I ruined at least 10k worth of tooling lol
