Pics of your tig torch setup :)
#56
Re: Pics of your tig torch setup :)
Do some of you guys increase the flow so you can weld with more amperage? (and not overheat the weld area)
Its odd, because I have never found it personally necessary to run over ~25cfh
#57
@ EJAYATE, thanks boss looks really good!
@ Boosted B, personally I float around between 20-25 with large gas lens. Seems to work for me. what are you trying to put more heat into? pipe, plate?
#58
I only turned it up because the cup flares out. I usually run 12-20cfm. My regulator is kinda wonky so im not sure what it "really" is. I also had the tungsten sticking out at least an inch.
#59
Ill post a pik mañana of my torch and I use small gas lense and #8 cup water cooled set my cfh at 25-35 cause I have to weld fast at work and I use 1/8 tungsten thoriated for sch10 budded with sch40...
It just all depends what If welding I use small gas lense with #8 long cup
I usually use big cups for.bigger.material any questions ask away
#61
I'm joining this! I'm so excited because this was the exact info I was trying to find as I just picked up a Miller Diversion 180
So this is where Markku went lol
#63
haha
Anyone have a good source for purchasing lenes and other supplies online?
Google brings up like a million....
My unit only came with 3/32 ceriated tungsten and #7 cup....
#65
#66
I know I'm bringing this thread back up, but I have a miller diversion 165 and bought the foot pedal for it. I'm wanting to change the torch out for something a little smaller/less bulky then what it came with. Is this possible? I believe this torch is a LS17. What torches do I look at? 17 series? Sorry for the newbie questions. Thanks in advance.
#69
Ignore the highlighted sections.
You need :
1x 54N63 - Insulator
1x 45V64 - Large gas lens (3/32") (or 45V116 for 1/16" electrode)
1x 53N87 - #12 Large diameter cup
Hope that helps.
EJ8chu
02-11-2008 03:09 PM
