New Welding Thread!
Old Mar 9, 2004 | 08:27 AM
  #1226
LSiTurbo's Avatar
Default Re: (hybridvteceg)
If there was a fabrication forum i could post a topic like...
"Where to get 3" 2 bolt Stainless Exhaust Flanges ????!?!?!!"
However, im stuck here in this neverending thread asking this question...
...So does anyone have any ideas on these flanges?
-Brian W.
Old Mar 9, 2004 | 09:18 AM
  #1227
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">looking to upgrade my 135 MIG. looking for a 220V input, and in the price range of 600-1000$$. who with a machine that fits into this category can give me some more info. uses range from exhaust stuff, to turbo stuff to suspension/caging, etc. basically an all around machine.</TD></TR></TABLE>
anyone?
Old Mar 9, 2004 | 09:29 AM
  #1228
project dc2's Avatar
Default Re: (LSiTurbo)
i know burns stainless has stialess exhaust flanges dunno bout 2 bolts tho
Old Mar 9, 2004 | 09:42 AM
  #1229
sporkcrx's Avatar
Default Re: (project dc2)
What drives me nuts is the "Decal Free Honda" forum. I mean WTF!?!?
Old Mar 9, 2004 | 09:54 AM
  #1230
dfoxengr's Avatar
Default Re: (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">What drives me nuts is the "Decal Free Honda" forum. I mean WTF!?!?</TD></TR></TABLE>
thats what im talkin about
Old Mar 9, 2004 | 01:24 PM
  #1231
LSiTurbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">i know burns stainless has stialess exhaust flanges dunno bout 2 bolts tho </TD></TR></TABLE>
Only 3 bolt... and i dont wanna usa V-bands either. Someone has got to have some stainless 2 bolts!!!!!!
Old Mar 9, 2004 | 01:50 PM
  #1232
.nate's Avatar
A fab forum would be awesome I've learned a lot from these welding threads!
Old Mar 9, 2004 | 03:24 PM
  #1233
hondaboii's Avatar
How about a Millermatic 175? or how about a hobart handler 175 MIG welder...
those two id look at..cuz they are good quality brands! and good welding..and its in your price range!
Old Mar 9, 2004 | 03:34 PM
  #1234
dfoxengr's Avatar
Default Re: (hondaboii)
anyone give e some experience withthose two types?
Old Mar 10, 2004 | 03:29 AM
  #1235
snoochtodanooch's Avatar
Default Re: (lazerus)
use image station, its worked fine for me.
Old Mar 10, 2004 | 08:46 AM
  #1236
lazerus's Avatar
Default Re: (snoochtodanooch)
ok, i forgot about imagestation.. pics of some of my newest welds/manis.. They're not quite done yet, but getting there
imagestation is killing my bw already, or something.
Old Mar 10, 2004 | 09:10 AM
  #1237
Sonny's Avatar
lazerus:
How are you cutting the holes in the tube running across the front so that #2 and #3 can enter there. Hole saw?
Thanks,
Sonny
Old Mar 10, 2004 | 09:13 AM
  #1238
lazerus's Avatar
Default Re: (Sonny)
plamsama or torch, then grind to fit.
i like to use the more expensive "T's" but yeah, people are cheap
Old Mar 10, 2004 | 10:11 AM
  #1239
plasma cut= messy =T at first i went that route but i didn tknow it was such a mess .. kidna stop using my plasma cutter now =T
Old Mar 10, 2004 | 10:27 AM
  #1240
Sonny's Avatar
Hole saw makes a perfect cut, but daaamn it takes a long *** time.
Sonny
Old Mar 10, 2004 | 10:54 AM
  #1241
Tinker219's Avatar
Default Re: (Sonny)
Plasma cutters own. Just have to put some metal pieces on the back side of the cut, so splatter doesnt get all over the place. I cut all my holes w/plasma, so far so good. On a time:money ratio I dont have a choice. Spend 15 seconds cutting a hole w/plasma cutter, or 30 min, and two hole saws cutting w/ a drill press. Oh, and having the drill bind up, send you and the manifold against the wall...lol.
So ya, plasma cutter.
Old Mar 10, 2004 | 11:21 AM
  #1242
dfoxengr's Avatar
Default Re: (Sonny)
bi-metal hole saws and my drill press dont take hardly any time at all to cut through steel.
Old Mar 10, 2004 | 11:59 AM
  #1243
lazerus's Avatar
i use a plasma, and then hand finish the cut with a carbide grinder....
are my pics showing up for you guys?
if not, you can checkm here
http://www.imagestation.com/al...nvite
Old Mar 10, 2004 | 12:08 PM
  #1244
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
i too very soon will have the delema of making a hole for the tubo flange on my custom log manifold. i wish my plasma worked here, but it hasn't in ages.. so i guess ol' faithfull hole saw will have to do. (i get alittle to exited with the tourches) heh
Old Mar 10, 2004 | 12:13 PM
  #1245
EFb18b's Avatar
hybridvteceg:
checkout the current deal on a lincoln sp175+ definitely a better machine then the mm175 but the hh175 comes in a close second(only tapped voltage) at http://www.weldingsupply.com
If you're afraid the 175 machines might be under powered, you can always step up to a mm210 for about $1200-$1300 w/o the spoolgun(depends on the special miller has on at the time) Normally though with proper prep and a couple of passes you should be able to weld just about anything on the car with a 175 especially with the sp175+. I don't own one yet but I have tried out all 3 machines and I thought the lincoln stood out the best.
Old Mar 10, 2004 | 01:45 PM
  #1246
dfoxengr's Avatar
Default Re: (Redlineracer)
redline, why did you like the linc over the mm? and do you know how long theyre going to have that sale on for? also do you know what type of gas input it takes, is it just a nipple on the back of the machine, ir is it a screw in fitting?
Old Mar 10, 2004 | 04:08 PM
  #1247
EFb18b's Avatar
I liked the mm but because of its somewhat "self driving" speed control mechanism, it felt like I had no control over it. The sp175+ has a continous voltage setting on it and you can pick what speed to set it at which allowed me to feel like I could fine tune the machine alot better to create much better welds then what I could do with the mm. Honestly, if the lincoln is way out of your range the HH175 is a great pic and the only thing you're really sacrficing is duty cycle.
Oh, and about the sale, I've been watching that site for over a year now and the price has never changed. $689+5 or 10 for shipping is a great deal and you won't be able to beat it. Trust me, I've already tried. You can be fluxcore welding right out the box or MIGging for $750-800 with a great machine. It's like I've told someone else on here before: miller and hobart have great machines no matter what but lincoln just can't be beat when you compare the 175+ with other machines in the same class. If you want to step it up a notch though, get a MM210.
Old Mar 10, 2004 | 04:33 PM
  #1248
dfoxengr's Avatar
ill prolly get the sp175+. like i said i already have a 130A machine and so ill be plug and play with this new one. alright. now to get a bit extra cash
Old Mar 10, 2004 | 04:59 PM
  #1249
1bar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">ill prolly get the sp175+. like i said i already have a 130A machine and so ill be plug and play with this new one. alright. now to get a bit extra cash</TD></TR></TABLE>
hmmm so thats y u want to go to the sperm bank
Old Mar 10, 2004 | 05:04 PM
  #1250
EFb18b's Avatar
Default Re: (1bar)
hehe I know one thing, if I buy the house i'm in now I'm gonna turn in my deer park water jug filled with coins for a MM251 :fwap: :fwap: :fwap: :fwap:
