My setup
Nice, everything looks good!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R@mon »</TD></TR><TR><TD CLASS="quote">
Is this the same fan that you have?
http://store.summitracing.com/...w=sku
</TD></TR></TABLE>Is this the same fan that you have?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88ED8 »</TD></TR><TR><TD CLASS="quote">Nice, everything looks good!!!
yup permacool 12 inch fans, one in front and one on the back. They cool the motor just fine in Miami weather
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tortis »</TD></TR><TR><TD CLASS="quote">did i miss it> how does she run?</TD></TR></TABLE>
no 1/4 times yet sorry
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R@mon »</TD></TR><TR><TD CLASS="quote">yup permacool 12 inch fans</TD></TR></TABLE>
That's the same fan I'm contemplating on getting, is it worth the hundred bucks, does it flow the 3000cfm it claims??
Can you do me a huge favor, measure how far the fan sticks out from the radiator... Thanks in advanced
Question out of curiosity, why not go with a VG trans?
Question out of curiosity, why not go with a VG trans?</TD></TR></TABLE>
check out this page:
http://perma-cool.com/Catalog/Cat_page16.html
the summit site has the flow wrong, 1650 is much more inline with what it should flow.
I measure about 4" depth required, permacool says 3 3/4". so figure 4" to be safe.
and as for the VG trans, i got one ready to go, just need to gather some funds to purchase the adapter plate/driveshaft
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R@mon »</TD></TR><TR><TD CLASS="quote">I measure about 4"</TD></TR></TABLE>
Is that 4 inches at the motor? I can't find any measurements for the frame part (the part marked in green)...
you going with the Mazwork kit?
I've always wanted to do a twin turbo v8 s14
they sell a complete kit for the vh45/vg trans, maybe one day
ill measure that part for you tomorrow and give you an exact dimension. and yes, the Mazworx kit is what i would use.
</TD></TR></TABLE>ill measure that part for you tomorrow and give you an exact dimension. and yes, the Mazworx kit is what i would use.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R@mon »</TD></TR><TR><TD CLASS="quote">ill measure that part for you tomorrow and give you an exact dimension. and yes, the Mazworx kit is what i would use.</TD></TR></TABLE>
Thanks!
Thanks!
Fantastic build. After seeing many KA-Ts this is definently up there as one of my favorites.
I also like how you re-routed the brake lines directly into the compartment and away from the manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigsyke »</TD></TR><TR><TD CLASS="quote">OP be carefull on the fan/radiator setup here. I found out your best bet is a copper/aluminum radiator with an altima fan. Ka's put out so much heat is non-sense.
Are you on zilvia?</TD></TR></TABLE>
my car will sit at 160-170 degrees in miami weather. even after a 1st-4th gear pull it warms up to maybe 180-190 and quickly cools down once I start cruising again.
You read that from some web page and you're regurgitating the information incorrectly. The copper/aluminum rad and altima fan setup was the best bang for the buck not the best cooling. I've never had any cooling issues with the numerous setups i've had while making more power than 99% of kat's out there so i fail to see where this overwhelming amount of heat being generated by the ka is evident.
must say this is one of the sickest street cars in south florida. car pulls off so hard..
R@mon vs 600+hp civic
http://s29.photobucket.com/alb...1.flv
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. »</TD></TR><TR><TD CLASS="quote">must say this is one of the sickest street cars in south florida. car pulls off so hard..
http://s29.photobucket.com/alb...1.flv</TD></TR></TABLE>
thanks cubish. Were you out there that night? Im pretty sure I saw a coupe with a HPC sticker on it.
yeah.. i was behind you guys most of the time.. everyone wanted to spectate and i couldnt get side by side..
the last race i i started about 2 cars behind you guys and i got close to the civic's back bumper in 4th...then i ran out of gas..lol 25psi+9000rpm+no gas=BOOM!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Olson »</TD></TR><TR><TD CLASS="quote">How tall are you front tires?
Justin</TD></TR></TABLE>
25.4" tall or 165/80/15
