Intercooler piping help needed
Hey guys
Just trying to figure out how to route the hot side intercooler piping. Having issues picturing how to do this. Stuck on this last piece and could use some points. I'm thinking of doing a 90 degree bend downwards and going under the front radiator support. Let me know what you guys think. thanks http://s10.postimage.org/9hh3kfhpx/photo.jpg http://s15.postimage.org/hr37xa6p3/photoo.jpg |
Re: Intercooler piping help needed
If you wanna drop the pipe that low, either go under the support or the fluid reservoir, I personally would just remove the fluid reservoir and go threw that way.
What is the set up may I ask?
Originally Posted by 90blackcrx
(Post 47819312)
But i guess you gotta loose a little to gain a little lol |
Originally Posted by RaceShopDepot
(Post 47819468)
- spoolin quick4ac manifold - silver surfer turbo - built engine cant remember that exact intercooler size, i wish i made proper measurements before buying. |
unless you go backdoor that windshield washer tank has to go, doesn't matter which honda you have
the hot pipe would hang too low if you ran it under the tank |
not too familiar with that chassis, but can't you just notch a 3" hole next to that large opening in order to get the pipe in there nice and tight, while also keeping the washer res?
This is a good example of where it would be nice to have a backdoor setup.
Originally Posted by SovXietday
(Post 47821463)
I'd recommend this option :) for a 5th gen lude http://www.urbanracer.com/gallery/ar...elude/0006.jpg |
I think it does as well, but if you trim the rad support a bit and place the backdoor high on the intercooler there is definitely room for 2.5" piping to fit through there. Of course this is considering he can/has access to that type of modification.
Otherwise, yeah, dump the resevoir and have fun. |
You can relocate the washer resevoir, they sell some that are quite small and can fit in alot of places, but obviously would need to be filled after you use them a little
I have one on my old cvic and switched it over to the passenger side fenderwell, holds about 750ml |
Washer fluid reservoir.
Lol. What's that ?! |
