Good entry level welding machines?
#76
Re: Re: (dynotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynotime »</TD></TR><TR><TD CLASS="quote">Actually the Craftsman is more liken'd to the HF 115v welder because the output amps range from 25-87 amps only, where as those quality welders go up to 135 amps.</TD></TR></TABLE>
So the craftsman one only put out 87 ? Are you sure ? If that is true I guess I'm going with the hobart one, this one puts out 125 correct ??
http://www.sears.com/sr/javasr...=TOOL
#78
Re: Re: (dynotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynotime »</TD></TR><TR><TD CLASS="quote">I called sears to give me the specs. actually the craftsmen only goes up to 85 amps, so the HF one is better by 2 lol. And you can weld with gas on the HF one!</TD></TR></TABLE>
You can weld with gas with the craftsman one also, can someone tell me how many amps this is, I read it and I'm pretty sure I'm correct, just want someone to double check me.
#80
Re: Re: (90blackcrx)
the craftsman one goes up to 87 amps. i couldnt find it on the box. but its right on the machine. its a great welder to start with. its done a lot of work for me. it was my first welder that i learned on and it works great. i'm not real great at welding but all the welds i have done are strong enough to jump on. i made a strut bar and i use it as my tow hook so its strong enough to pull a 2200lb car. but now i am taking arc classes (because i have to before i get to mig and tig) that use 300amp machines and theres a big difference in power
#81
Re: Re: (98AccordEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98AccordEX »</TD></TR><TR><TD CLASS="quote">the craftsman one goes up to 87 amps. i couldnt find it on the box. but its right on the machine. its a great welder to start with. its done a lot of work for me. it was my first welder that i learned on and it works great. i'm not real great at welding but all the welds i have done are strong enough to jump on. i made a strut bar and i use it as my tow hook so its strong enough to pull a 2200lb car. but now i am taking arc classes (because i have to before i get to mig and tig) that use 300amp machines and theres a big difference in power</TD></TR></TABLE>
Thanks, I think I'm gonna get the hobart one.
EF9_TryMe
Welding / Fabrication
02-20-2012 09:28 PM
PINKS
22
11-14-2006 10:31 AM
SinSeven
16
10-25-2006 12:32 PM
