bolted a hole in the block (help please)
Old 09-23-2012, 05:20 PM
stat3ofm1nd's Avatar
Default bolted a hole in the block (help please)
i bolted a hole in the block its near the oil filter so theres alot of oil pressure i want to know how i can seal the hole and should i keep the car after i do this here are some pictures
Old 09-23-2012, 05:30 PM
Default Re: bolted a hole in the block (help please)
there has to be someone that can help ??
Old 09-23-2012, 05:34 PM
bgdriver's Avatar
pre heat the block before it's welded. expect deck/bore/line hone after.
Old 09-23-2012, 06:46 PM
vtechjunkie's Avatar
Kinda hard to see what that passage is, but with a decent welder you should be able to get it all plugged up, withough even tearing it down. There is enough metal there that who ever does it shouldnt heat soak the block, thus warping it. But as for "keeping the car", if you sold it that way, just let your customer know about it. But if repaired properly, it shouldn't even be mentionable.
Old 09-23-2012, 06:55 PM
alright thanks man
Old 09-23-2012, 08:58 PM
EF9_TryMe's Avatar
How the hell did that happen ? O_o?
Old 09-24-2012, 05:03 AM
bolt was to long just kept on tighening it
Old 09-24-2012, 08:39 AM
SQ is the SQUAD's Avatar
maybe you can tap the hole and put a hex plug in it
Old 09-24-2012, 09:11 AM
JDM JEFFREY's Avatar
Tap and plug
Old 09-24-2012, 11:30 AM
Vagitarian's Avatar
tap and plug for sure
Old 09-24-2012, 06:23 PM
thanks guys i tapped it and put thread lock and apoxy also hope it works i want to keep this car has been great and just dumped 600 just in parts cause i wanted to keep it
Old 09-24-2012, 06:53 PM
spAdam's Avatar
Change the oil a couple of times after you tap and plug. Just in case you get any shavings in there.
Old 10-11-2012, 07:11 PM
yayitruns's Avatar
^super important, it would suck for all those new parts to go to waste.
Old 10-15-2012, 10:27 AM
that-guy's Avatar
might be worth some extra insurance to put some solid tack welds on that bolt just incase the thread locker doesn't hold up...so long as you used the same material for the bolt as what the block is made of
tangerinebeast
03-29-2011 11:56 AM
jksmith
05-12-2009 12:27 PM
gATOr65
07-04-2008 05:21 PM
RTW DC2R
05-31-2006 04:47 PM
Quick Reply: bolted a hole in the block (help please)
