Bolt-in cage comparison
Old Jan 28, 2006 | 10:07 AM
DocSean's Avatar
Default Bolt-in cage comparison
I am working on making a simple rollbar setup for my CRX right now. We've got everything bent and ready to put in, however....the support bars (which I am mounting behind the rear speaker grills similiar to the autopower bar) cannont come back out of the mounting position without gettig cought. We are having a tough time getting the bars correct so that the kit can come out without having to remove interior etc. My question is, would I be risking much if I simply used a bolt-on design to connect the support bars to the main hoop?
Old Jan 28, 2006 | 08:24 PM
DocSean's Avatar
Anyone....anyone?
Old Jan 29, 2006 | 07:41 AM
93DA6's Avatar
Default Re: (spankjelly)
Autopower bars use a bolt on setup to connect the rear support tubes to the main hoop - so i'd say you'd be ok.
Old Jan 29, 2006 | 12:15 PM
DocSean's Avatar
Default Re: (93DA6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93DA6 &raquo;</TD></TR><TR><TD CLASS="quote">Autopower bars use a bolt on setup to connect the rear support tubes to the main hoop - so i'd say you'd be ok.</TD></TR></TABLE>
Awesome, I thought they were welded!
Mr.OB*GYN_Rhett
Welding / Fabrication
Oct 20, 2008 12:19 PM
96 GSR-T
14
Mar 24, 2008 09:20 AM
Emerica
Nov 9, 2007 09:35 AM
.one lane
Mar 16, 2006 06:39 AM
CaptainMorgan
May 21, 2005 05:55 PM
