OH 1990 Civic SI, All motor JDM B18c, Tuned, nice suspension, CLEAN.
1990 Honda Civic SI
*150k on body
*4300 on motor (cluster rolled back from the time of the build)
Interior in good condition (SI seats are mint)
*5000k HID's
*PasswordJDM smoked amber corners
*PasswordJDM smoked amber sidemarkers
*Revo Technica stage 2 camber kit
*ETD traction bar
*Recently replaced front rotors and brake pads
*Recently replaced rear drums
*Antenna block off
*Mild wire tuck w/ Full RYWIRE Harness (battery behind passenger seat, fusebox behind glovebox, tucked headlight harness, etc)
Exterior, I list in fair condition, only due to the fenders being flat black, hood being "rising sun flat white/black, one dent in the drivers side door (can be pdr'ed), and the car does have original paint. I would say 7/10 on paint, but overall *condition* 8.5/10.
BLOCK
ENGINE: BUILT BY D&D ENGINE SERVICE IN INDIANA
****LESS THAN 4500 MILES ON THE MOTOR****
*B18C1 block, bored .20 over, decked, cleaned, etc
*CP 81.5mm 12.5:1 c/r pistons
*Eagle Rods
*Micropolished GSR crank
*All brand new honda main and rod bearings
*New water pump
*New oil pump
*New timing belt
*New headgasket
*All gaskets and seals were replaced at time of rebuild
*ARP main studs
*ARP headstuds
*COMPLETELY BALANCED! (Done by John Davis Fabrication)
HEAD
*B16A head
*Portflow head
*3 angle valve job
*Ported and polished
*Milled
*Cleaned
*Skunk2 PRO1 camshafts
*Skunk2 PRO series dual valvesprings
*Skunk2 PRO series titanium retainers
*Ferrea valves
*AEBS intake manifold (portmatched to TB)
*blox 66mm throttle body
*P2R intake manifold gasket
*P2R TB gasket
*BDL bronze fuel rail
*Accell 310cc injectors
*3" Integra XSI intake arm
*Fujuita Cold Air
*Apexi 4-2-1 headers
*Omni test pipe 2.5"
*Invidia exhaust 2.5"
TRANS
*B16A cable trans Ys1/LSD.
*Exedy Stage 1 clutch
*Fidanza lightweight flywheel
*Skunk2 short shifter
*Skunk2 weighted shift ****
SUSPENSION
*KSport Kontrol Pro 36-way coilovers
*KSport rear lower control arms
*Lower tie bar
*PasswordJDM 3 point front tower bar
*PasswordJDM 2 point rear tower bar
autopower 6 point roll cage
ENGINE MANAGEMENT/MISC
*Hondata S300 installed in a P28
*Tuned by Dave Blundell aka (Blundar) Dyno on a very moderate tune 180hp 158tq
*Fluidyne full size radiator w/ slim fan
This car has a lot more room for power! It has never seen rain snow salt etc... asking $6500 and I will not trade for grandma's walker or your stepdads atv. This car is no joke all offers will be considered as long as they are reasonable. Small trades plus cash are welcome to lower the price a little bit.
Also, the car has had quite a few "maintenance items" replaced, such as the following
Brakes all the way around (rotors/pads front, drums/wheel cyl., etc rear)
Tie rod ends, inner/outer
Ball joints, upper/lower
Axles
all cotter pins/crown nuts on suspension, obviously.
Arp extended wheel studs in the front (car was never on, nor launched on slicks/dr's.)
All of those parts have less than 5k on them.
Like I said, the car only has 1 hour of tuning, and honestly has not even began to scratch the surface of making any kind of serious adjustments to timing, or fuel maps. Honestly the car is kind of just base mapped, so that it would be safe to be driven and safe to race.
http://c3.ac-images.myspacecdn.com/i...9ace98d742.jpg
http://c1.ac-images.myspacecdn.com/i...5539022538.jpg
http://c4.ac-images.myspacecdn.com/i...2893a5c65f.jpg
http://c1.ac-images.myspacecdn.com/i...9db5be0e5c.jpg
http://c1.ac-images.myspacecdn.com/i...3edf045fa4.jpg
http://c2.ac-images.myspacecdn.com/i...223951aee9.jpg
http://c2.ac-images.myspacecdn.com/i...85a63b7f9d.jpg
http://c4.ac-images.myspacecdn.com/i...c072f0cf6b.jpg
http://c3.ac-images.myspacecdn.com/i...aaab72b6b2.jpg
http://c2.ac-images.myspacecdn.com/i...130553204d.jpg
http://c1.ac-images.myspacecdn.com/i...182b65d498.jpg
http://c3.ac-images.myspacecdn.com/i...d041dd5092.jpg
http://c2.ac-images.myspacecdn.com/i...3a9f39707d.jpg
$6500 and it's yours. Couple more hours in tuning, and you have a caged, built all motor b series car, ready for auto X, drag racing, or just fun...
*150k on body
*5000k HID's
*ETD traction bar
*Antenna block off
BLOCK
*Eagle Rods
*New water pump
*New oil pump
*New timing belt
*New headgasket
*ARP main studs
*ARP headstuds
HEAD
*B16A head
*Portflow head
*3 angle valve job
*Milled
*Cleaned
*Ferrea valves
*P2R TB gasket
*Fujuita Cold Air
TRANS
SUSPENSION
*Lower tie bar
Axles
Re: 1990 Civic SI, All motor JDM B18c, Tuned, nice suspension, CLEAN.
bump for viewing the smallest pics in the world!!!! GLWS and btw: love the hood.
Eviltek1989
09-10-2010 04:42 PM
pgtmatt
06-12-2010 08:07 PM
winteR`
12-09-2008 11:05 PM
motiondc5
05-19-2007 11:31 PM
